linux_juggler
Posted: Mon Aug 29, 2005 7:24 am Post subject: Getting started with Mandriva-Cover disks- installtion error |
first of all i just want to thank you all for the good work .
secon :
am trying to install mandrava on my VMware 5.0 so that i can test it b4 i try to install it on my computer ..
i know mandrake ( i have used the version 7 ) and i know that you cannt excpect the errors that you may see in your face when you try to install it .
so i start my VMware and made it for mandrake and now its okay to start installation .
i start the installion , and every thing was okay untill i got an error that say that i didnt select the base program ?
althought i checked on every box .
the second time i try to install it , i got an other error that there is an error accoured when they try to install an rpm file called lib* and do i want to continue any way , even if say yes i got an other error with other correpted rpm .
so can any one help me with that ?
best regards |
Dominic
Posted: Thu Sep 08, 2005 4:15 pm Post subject: Re: Getting started with Mandriva-Cover disks- installtion e |
| linux_juggler wrote: | | i got an other error that there is an error accoured when they try to install an rpm file called lib* and do i want to continue any way , even if say yes i got an other error with other correpted rpm . |
Im having the same problem!!! and Im using VMWare 4... I wonder if anyone knows why this error is happeining???
Dominic |
linux_juggler
Posted: Thu Sep 08, 2005 4:23 pm Post subject: |
if you read the mag you can see that its regular to have something like that...
its mandrake any way |
nelz Moderator
Posted: Thu Sep 08, 2005 4:24 pm Post subject: RE: Re: Getting started with Mandriva-Cover disks- installti |
I con confirm that it is not an inherent problem with VMWare, I've installed form the discs not VMWare 5. however, the CD handling is a little suspect in VMWare at times (or it plain doesn't like my drive) so I usually rip the CDs to ISO files and install from them. It is faster and more reliable.
| Code: | | dd if=/dev/cdrom of=/some/file.iso bs=2048 |
does it, then you can install from the ISO images in VMWare. Copying the discs also gives an initial test for read errors (which is what you are seeing here) without running through most of the installation before finding out. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Dominic
Posted: Fri Sep 09, 2005 9:56 am Post subject: Re: RE: Re: Getting started with Mandriva-Cover disks- insta |
| nelz wrote: | | so I usually rip the CDs to ISO files and install from them.. |
I'll give it a go...
thx |
Dominic
Posted: Fri Sep 09, 2005 11:10 am Post subject: Re: Getting started with Mandriva-Cover disks- i |
I gave it a go... created the ISOs and mapped them in VMware...
No change. The first package that fails is readline, right at the beginning of the process and it just continues downhill from there . All I can assume is that I have been given duff disks |
nelz Moderator
Posted: Fri Sep 09, 2005 11:42 am Post subject: RE: Re: Getting started with Mandriva-Cover disks- i |
It does sound like it. although I would expect a faulty disc to fail when you copy it to the ISO too. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
