Learn the basics of Perl
Postby DebianNovice » Sun May 15, 2011 1:31 pm
Hi
Ive just tried out the Learn Basics of Perl and it is not as straight forward as expected. Ive just downloaded imagemagick on Ubuntu using
sudo apt-get install imagemagick --fix-missing
and running the script now I get
Can't locate Image/Magick.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.10.1 /usr/local/share/perl/5.10.1 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.10 /usr/share/perl/5.10 /usr/local/lib/site_perl .) at ./myboardgame.pl line 5.
BEGIN failed--compilation aborted at ./myboardgame.pl line 5.
Is the magazine contents incomplete or is there something else I am missing ?
thanks
DebianNovice
Postby ppmt » Sun May 22, 2011 5:35 pm
you probably needs to install perlmagick as well
this is the glue between perl and imagemagick
ppmt
Postby lesleyb » Sun Mar 25, 2012 3:15 pm
I appreciate the OP posted a year ago now.
However http://learn.perl.org is a useful resource as are the mailing lists for beginners at http://lists.perl.org/tag/beginners.html
Regards
L.
lesleyb
