Got stuck with Android dev environment setup.
leke
PostPosted: Wed May 04, 2011 7:18 pm    Post subject: Got stuck with Android dev environment setup. Reply with quote
Hi, I'm trying to get an Android development environment up and running. I'm following this guide and everything went smoothly until I got here...
Quote:
At this point we need to install platforms and optional additional plug-ins or sample codes. Start Android SDK manager:
android-sdk-linux_86/tools/android
So I ran it like this...
Quote:
asdf@asdf-laptop /opt/android-sdk-linux_x86/tools $ sudo bash android
SWT folder '/opt/android-sdk-linux_x86/tools/lib/#
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0xb6f45dbc, pid=6396, tid=3067009904
# JRE version: 6.0_24-b07
# Java VM: Java HotSpot(TM) Client VM (19.1-b02 mixed mode, sharing linux-x86 )
# Problematic frame:
# V [libjvm.so+0x231dbc]
# An error report file with more information is saved as:
# /opt/android-sdk-linux_x86/tools/hs_err_pid6396.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
#' does not exist.
Please export ANDROID_SWT to point to the folder containing swt.jar for your platform.
Err...Can anyone suggest what to do now?
Thanks.
I codes here: http://notsure.tk
ethernet
PostPosted: Thu May 05, 2011 11:10 am    Post subject: Reply with quote
It might be worth trying doing it through Eclipse (as per these steps). That worked for me. It takes ages for those components to download.
leke
PostPosted: Thu May 05, 2011 12:06 pm    Post subject: Reply with quote
It's a similar guide. I've done everything up to...
Step 4. Adding Platforms and Other Components
...and get the error running the Android command from /tools
But thanks anyway Wink
ethernet
PostPosted: Thu May 05, 2011 3:28 pm    Post subject: Reply with quote
What I meant is that you can also manage AVDs through Eclipse. Should invoke the same program in any case.
Any luck trying it without root privs?
cd to /path/to/android-sdk-whatever/tools/
and then launch ./android
The emulator is sooooo slow, you'll be happy *not* to get past this little error Smile
PostPosted: Thu May 05, 2011 3:55 pm    Post subject: Re: Got stuck with Android dev environment setup. Reply with quote
Thanks.
Have you tried doing what the error message suggested?
Bazza
PostPosted: Thu May 05, 2011 4:43 pm    Post subject: Reply with quote
I'd thought about this platform but......
......I have no idea what I could "develop" that hasn't already been done.
Also, not sure if I am capable of doing so in the first place. ;o(
73...
Team AMIGA...
leke
PostPosted: Thu May 05, 2011 5:21 pm    Post subject: Reply with quote
You just reinvent something. Angry Birds is just a reinvention of Yeti Sports with a lame storyline.
Oh, and if you google Yeti Sports, be warned, it involves cruelty to penguins.
My first effort will be a copy of Whack a mole, but with a twist Wink
Surprised it worked! (wtf?).
Didn't really understand what the error message was going on about, but I guess that part was telling me to change a path in some file called ANDROID_SWT to point to some other file called swt.jar, but no need now as it seems to be working.
PostPosted: Thu May 05, 2011 6:53 pm    Post subject: Reply with quote
The message was telling you to set the ANDROID_SWT environment variable to the directory containing that file, and then export it.
Code:
locate swt.jar
export ANDROID_SWT="/path/from/above/"
Have you rebooted since the problem occurred? It is possible the variable was defined, but not available in your existing environment.
leke
PostPosted: Thu May 05, 2011 9:50 pm    Post subject: Reply with quote
Yep, i think so too. I can execute with sudo now too -- which I needed to do, to save the API I installed from the set up app.
It's times like these I miss the little windows nag, "Restart required. Restart now?" Rolling Eyes
@ethernet
Oh, and I see what you mean by the emulator being slow, OMG!
PostPosted: Fri May 06, 2011 12:05 am    Post subject: Reply with quote
Except you don't need to reboot to set a single variable, well, not in Linux.
leke
PostPosted: Sun May 08, 2011 1:12 pm    Post subject: Reply with quote
Would you have to possibly log out and then log back in again?
As for development, wow, the emulator is so slow to work with on my hardware, I'm not able to currently use it. I'm googling for other ways -- perhaps a way I can hook up my tablet and send code to it to execute.
ethernet
PostPosted: Sun May 08, 2011 2:20 pm    Post subject: Reply with quote
If you can afford it, give a standard Android image 512 MB RAM. For a tablet, go for 1 GB, if possible.
Connect your Android device and run
Code:
/path/to/android-sdk/platform-tools/adb devices
If it's detected here, Eclipse should launch the app on the physical device over launching the emulator, by default. You can double check this by right-clicking on your app in Eclipse --> Run As --> Run Configurations. Bring up the Target tab and ensure 'Automatic' is selected.
You also need to enable USB debugging on the device and allow installation of non-market (third-party) apps in the phone's preferences for this to work.
I had to write a udev rule on openSUSE 10.3 to detect a HTC Desire but then it 'just worked'.
PostPosted: Sun May 08, 2011 6:57 pm    Post subject: Reply with quote
No, although that would do it. All you actually need to do is what the message says, export the variable.
leke
PostPosted: Mon May 09, 2011 7:16 am    Post subject: Reply with quote
Ah, ok. I finally got it after I googled it, and it's what I know as, 'setting the path variable'. Rolling Eyes
