Ripping audio track from DVD HOWTO
Postby Dutch_Master » Wed Mar 30, 2011 2:54 am
Title says it all, isn't it? Here's a quick HOWTO, distilled from various sources, including my own small experiments, based on a Debian Lenny system (but should work on any derivative too).
First, install the required tools:
aptitude update && aptitude install lsdvd transcode vorbis-tools
(note: do enable/enter the debian-multimedia repo's (or similar for your distro) in your sources.list!)
Transcode is the tool for the hard work, and it's home is the cli. No GUI I'm aware of, AFAIK! Next, find out about the dvd you want to rip an audio track from:
lsdvd /dev/dvd
You may need to change the drive according to your system. The result looks something like this:
Disc Title: STING_LIVE_IN_BERLIN
Title: 01, Length: 02:04:38.220 Chapters: 23, Cells: 24, Audio streams: 02, Subpictures: 00
Title: 02, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 00, Subpictures: 00
Title: 03, Length: 00:14:27.133 Chapters: 03, Cells: 03, Audio streams: 01, Subpictures: 00
Longest track: 01
This tells you the most likely title you need is title 1, with 23 chapters/songs (in this case) to choose from and 2 audio formats. The tricky bit is to find out what chapter number the track has you want to rip. Start counting ;)
The transcode command has the following format:
transcode -x dvd -i /dev/dvd -T <title>,<chapter>,<angle> -a <audiotrack> -y null,ogg -b 192 -E 44100,16,2 -m '<songtitle>.ogg'
In practice, here's a sample command:
transcode -x dvd -i /dev/dvd -T 1,18,1 -a 0 -y null,ogg -b 192 -E 44100,16,2 -m 'Every_breath_you_take.ogg'
Don't omit the -x flag, as it tells transcode what discformat to read. The -i flag is for the device, the -T tells transcode to work with title 1, chapter (song) 18 and angle 1, the -a flag specifies the audio track, -y says not to encode video and encode the audio stream in Ogg-Vorbis, the -b specifies bitrate, -E controls sample rate etc, while -m specifies the name of the output file. Hit enter and wait for it to finish. Given transcode lives on the cli, making a small loop to process every track is relatively easy, but you may want to choose an output name of "Track$1" to avoid files just encoded get written over ;)
Now, given the right encoders transcode can also transcode video formats, just replace the "null" in the -y flag by the name of the codec you want to use (h264, MPEG4, WMV if you really must, and more to choose from) but that kinda beats the idea of ripping a dvd of its audio tracks ;) Do note that other audio formats are also supported, including MP3, WAV and FLAC. Adjust commands to suit your taste :)
As stated earlier, this is compiled from various sources, including, but not exclusive, the Ubuntu forum and the exhaustive transcode man-page. The above command works for transcode verion 1.0.7 and probably later too, although I haven't tested that nor any previous versions. Check your version with
transcode --version
Postby Rhakios » Wed Mar 30, 2011 5:48 am
So... did you really intend this for the new Hints & Tips section?
Postby Dutch_Master » Wed Mar 30, 2011 12:08 pm
Would be a good candidate, wouldn't it? ;) (overlooked that one :oops: )
Return to Hints and tips
