Another WIndows 7 question...
Postby Bazza » Mon Jan 31, 2011 6:06 pm
This is probably in towy71`s or ollie`s domain...
OS == Windows 7 64 bit ONLY, any version...
(Don`t bother with the 32 bit versions.)
Can you guys do this quick test for me...
Assumption, DEBUG.EXE still exists in W7 64 bit...
Open up a STANDARD CLI, (Command Prompt), window.
Type DEBUG.EXE[RETURN/ENTER]
When running type:-
d0:417[RETURN/ENTER]
Note down the FIRST value as shown in the HEX dump.
Now press CAPS LOCK to enable the caps lock.
Type the same as above:-
Note down this value again and exit DEBUG.EXE by
typing:-
q[RETURN/ENTER]
Exit the CLI as normal...
Post the two values on here please...
Assuming it works as expected I`ll know what they mean.
If DEBUG.EXE does not exist or execute then let me know
that too...
TIA to anyone who replies...
73...
Team AMIGA...
Bazza
Postby Marrea » Mon Jan 31, 2011 6:51 pm
Hi Bazza
I have no idea what debug.exe is but it doesn't seem to exist in Windows 7 64 bit. This is the result I got from running DEBUG.EXE
‘DEBUG.EXE’ is not recognized as an internal or external command, operable program or batch file.
Marrea
Postby Bazza » Mon Jan 31, 2011 7:47 pm
Hi Marrea...
Thanks for that.
I did expect that result as DEBUG.EXE is 16 bit code and
64 bit OS can`t run 16 bit code directly. It has to run via
XP emulation mode...
Again many thanks for your time...
I`ll have to look laterally at what I want to do...
73...
Team AMIGA...
Bazza
Postby Marrea » Mon Jan 31, 2011 9:07 pm
Bazza wrote:Again many thanks for your time...
No prob, only took a second as I happened to be in Windows at the time.
Marrea
Re: Another WIndows 7 question...
Postby towy71 » Mon Jan 31, 2011 10:34 pm
Bazza wrote:This is probably in towy71`s or ollie`s domain...
I can't speak for ollie but I don't have windows 7 and very seldom use any of the older versions either, I stopped helping people with windoze last year ;-)
Postby Bazza » Fri Mar 11, 2011 11:05 pm
Hi again...
Another question about Windows 7, 64 bit only again...
Does the default Command Prompt have the "CLS" command,
(resident or transient).
TIA guys...
73...
Team AMIGA...
Bazza
Postby bobthebob1234 » Sat Mar 12, 2011 9:36 am
In my win 7 64-bit virtual machine I get the same results for debug and yes cls (clear screen) still works.
bobthebob1234
Postby Bazza » Sat Mar 12, 2011 12:26 pm
Hi btb...
Thanks that`s all I wanted to know... :)
73...
Team AMIGA...
Bazza
