Which old nvidia graphics card?
Postby finster » Sun Jan 16, 2011 4:48 pm
Hi all,
I have an old AMD Sempron desktop PC that I've got Ubuntu 10.10 installed on. Everything works great, but the built-in "S3 UniChrome Pro" motherboard graphics isn't the best.
The motherboard has an AGP slot, so I was thinking of picking up a very cheap dedicated graphics card from ebay.
Is there a minimum I should be aiming at to get Compiz working for example? I'd prefer a nVidia card, as that's what I have always used, but all opinions welcome.
Postby PCNetSpec » Sun Jan 16, 2011 5:29 pm
Minimum would probably be a GeForce 4 MX
or anything supported by the 96.43.19 driver.
(MUST be the 96.43.19 as this is the only 96 driver that works with Xorg 1.9 as used in Maverick)
http://www.nvidia.com/object/linux-disp ... river.html
(click Supported Produts at above link)
But personally I'd say go for a minimum of a Geforce 5 series card, that uses the 173 drivers.
Or even better...
See here for an NVIDIA chip comparison chart:
Linux in the UK
The Linux Community Forum
Postby finster » Sun Jan 16, 2011 5:45 pm
Thanks for the great info.
That product from ebuyer is a little on the expensive side - probably worth more than the PC!
I'm thinking of going for a nVidia Geforce FX5200 128MB - this seems to be supported on the nVidia 173.14.28 page.
Thanks again.
Postby finster » Thu Jan 20, 2011 8:13 pm
Just as an update to this - I bought an nVidia AGP 128mb FX5200 card off ebay (under £9 including postage) and Ubuntu works great with "extra" visual effects. The restricted driver version 173 was installed after I went into "Additional Drivers".
Thanks again for the pointer.
