Coding Academy - Project 4 Question
chriswadams
PostPosted: Sun Jul 11, 2010 10:44 pm    Post subject: Coding Academy - Project 4 Question Reply with quote
Well, I'm back again with another strange error message ...
I'm working on Project 4 of the Coding Academy (the 'Fish Feast' game), and I'm having a problem with SDL. It refuses to display the 'background.jpg' file in the window. In fact, every time I run the program, it simply crashes with this message:
Quote:
Unhandled Exception: SdlDotNet.Core.SdlException: Couldn't open media/background.jpg
at SdlDotNet.Graphics.Surface..ctor (System.String file) [0x00000]
at fishfeast.MainClass.Main (System.String[] args) [0x00014] in /home/chris/Projects/fishfeast/fishfeast/Main.cs:20
I followed Paul's suggestion to copy the files to the "fishfeast/fishfeast/bin/debug" folder, but I still get the error message. I have changed the program's 'Output Path' to "fishfeast/fishfeast" as Paul instructed (and setup a 'media' file there with the 'background.jpg' and 'logo.png' files) to no avail. I have double checked the list of dependencies (on p.32 of the Coding Academy) to be sure I have them all installed, and I have even installed the dependencies listed at the "SDL.NET" site ( http://cs-sdl.sourceforge.net/index.php/The_absolute_newbies_guide_to_SDL.NET ) to make sure I have those available. I still get the error message.
One other thing I have noticed is that when I tried to add the following command:
Code:
sfcMain.Fill(Color.DarkBlue);
I simply got a black window. No other colors would work.
Any advice would be greatly appreciated.
chriswadams
PostPosted: Sun Jul 11, 2010 11:02 pm    Post subject: Reply with quote
Are you using the supplied DVD or running Mono from a 64 bit OS ?
chriswadams
PostPosted: Mon Jul 12, 2010 11:24 pm    Post subject: Reply with quote
Ram --
I'm using 32-bit Ubuntu 10.04.
Incidentally, I tried booting from the included DVD in Live mode, and running the edition of Fish Feast from the DVD, and all I got was a blank, black window. Nothing else.
Also, the SDL site has a list of recommended dependencies, and I made sure they were all installed on my computer. They all installed fine except one, called "libsdl1.2debian-all" . That one insisted on uninstalling my ubuntu-desktop package (of all things), so I skipped it. I hope that isn't the one dependency I really, really need!
chriswadams
PostPosted: Tue Jul 13, 2010 9:25 am    Post subject: Reply with quote
I don't have libsdl1.2debian-all installed but I do have libsdl1.2debian installed.
kdamica
PostPosted: Fri Sep 03, 2010 11:39 pm    Post subject: Reply with quote
I'm having the same problem. Here's the error I get:
Module loaded: Fishfeast, Version=1.0.3898.33352, Culture=neutral, PublicKeyToken=null.
Module loaded: SdlDotNet, Version=6.1.0.0, Culture=neutral, PublicKeyToken=26ad4f7e10c61408.
Module loaded: System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a.
Module loaded: Tao.Sdl, Version=1.2.13.0, Culture=neutral, PublicKeyToken=9c7a200e36c0094e.
Fontconfig warning: "/etc/fonts/conf.d/51-local.conf", line 587: saw number, expected matrix
Stacktrace:
at (wrapper managed-to-native) Tao.Sdl.Sdl.SDL_MapRGBA (intptr,byte,byte,byte,byte) <0x00090>
at (wrapper managed-to-native) Tao.Sdl.Sdl.SDL_MapRGBA (intptr,byte,byte,byte,byte) <0xffffffff>
at SdlDotNet.Graphics.Surface.GetColorValue (System.Drawing.Color) <0x0016f>
at SdlDotNet.Graphics.Surface.Fill (System.Drawing.Rectangle,System.Drawing.Color) <0x0011b>
at SdlDotNet.Graphics.Surface.Fill (System.Drawing.Color) <0x001c3>
at Fishfeast.MainClass.Main (string[]) [0x00014] in /home/kenny/Projects/Fishfeast/Fishfeast/Main.cs:17
at (wrapper runtime-invoke) Fishfeast.MainClass.runtime_invoke_void_object (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
/usr/bin/mono() [0x47b77f]
/usr/bin/mono() [0x4aef3f]
/lib/libpthread.so.0(+0xf8f0) [0x7feea8b8b8f0]
/usr/lib/libSDL-1.2.so.0(SDL_MapRGBA+0) [0x7feea6f36320]
[0x40025b30]
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
PostPosted: Sat Sep 04, 2010 12:54 am    Post subject: Reply with quote
Need to see your code
kdamica
PostPosted: Sat Sep 04, 2010 5:53 am    Post subject: Reply with quote
Code is the same as in the lesson. Works if I comment out the fill color line.
Code:
using SdlDotNet.Core;
using SdlDotNet.Graphics;
using SdlDotNet.Input;
using System;
using System.Collections.Generic;
using System.Drawing;
namespace Fishfeast
   class MainClass
      static Surface sfcMain;
      public static void Main (string[] args)
         sfcMain = Video.SetVideoMode(1024,768);
         Events.Quit += new EventHandler<QuitEventArgs>(Events_Quit);
         Events.Run();
      static void Events_Quit(object sender, QuitEventArgs e){
         Events.QuitApplication();
amos
PostPosted: Mon Nov 29, 2010 3:05 pm    Post subject: Reply with quote
I'm having exactly the same problem on Debian amd64. Has anyone come up with a solution or a work around?
May the wind at your back never be your own!
PostPosted: Tue Nov 30, 2010 1:11 am    Post subject: Reply with quote
As far as I know there's a bug in SDL when running 64 bit OS which causes a blank/black screen. No idea if it's been resolved or not.
All the SDL stuff from the academy I did, I ended up doing on 32 bit Ubuntu.
euphogeeza
PostPosted: Thu Dec 23, 2010 2:14 pm    Post subject: SDL Not working on x86_64 :-( Reply with quote
I thought I must be doing something wrong. I checked, double checked, deleted and re-wrote code. Aaghh! Crying or Very sad
I'm running OpenSUSE 11.2 Emerald 2.6.31.14-0.4-desktop SMP PREEMPT x86_64.
Does anyone know if there is a fix for 64 bit O/S?
