.co.uk to .com transition complete
Postby M-Saunders » Tue Nov 09, 2010 11:39 am
Hi folks,
All .co.uk URLs for this site should redirect to .com now -- please let me know if there are any problems. If you've been using the forums in the .co.uk version, you'll need to log in again to set the .com cookie, and then all will be sorted.
Thanks!
Mike
M-Saunders
Postby donoreo » Tue Nov 09, 2010 2:13 pm
Gee that only took.....how long? :)
I cannot deny anything that I did not say.
donoreo
Postby M-Saunders » Tue Nov 09, 2010 2:36 pm
Well, adding the RewriteRule took about 30 seconds, and restarting Apache another 5... so 35 seconds ;-)
M
M-Saunders
Postby donoreo » Wed Nov 10, 2010 2:36 pm
Hence my question :) Approval processes can be a bitch :)
donoreo
Postby Ram » Fri Nov 12, 2010 2:27 pm
donoreo wrote:Hence my question :) Approval processes can be a bitch :)
Agreed :D
Postby jjmac » Wed Nov 17, 2010 8:41 am
Howdy All,
I must be really losing it or something because i hadn't really noticed. Except at first. But that was an easy fix, i just used the .com instead.
Notice how that doesn't make any sense or otherwise is irrelevant ...
http://counter.li.org
Return to This Website
Users browsing this forum: Majestic-12 [Bot] and 1 guest
