Opening and processing files in Python
Postby PhilC » Wed Aug 17, 2005 3:16 pm
I'm trying to make a start in Python programming. I consider myself competant with Perl, and I want to do some of the same things which are easy in Perl, in Python.
In particular, I want to be open a file and process each line at a time.
In Perl I just do:
while (<>) {
doSomethingWith ($_);
I've had a browse around python.org, but can't find any good references to opening and processing files.
Can anyone tell me how to do the above Perl code in Python? I really would appreciate it, thanks.
PhilC
RE: Opening and processing files in Python
Postby nelz » Wed Aug 17, 2005 5:35 pm
lines = open('foo/bar').readlines()
for line in lines:
   dosomethingwith(line)
Postby PhilC » Thu Aug 18, 2005 12:34 pm
Thanks for getting me started nelz, I'll be using that a lot in the future.
I did a little bit more digging though since the perl diamond operator can do a little bit more than this code.
i.e. it will read each file given as an argument to the program and process each file in turn. Much more useful than that though is that it can read input from stdin or a pipe.
Just in case anyone else is looking for this feature in Python, I had another look around python.org and found this code: (http://www.python.org/doc/2.2.3/lib/mod ... input.html)
import fileinput
for line in fileinput.input():
dosomethingwith (line)
PhilC
Postby overflow » Wed Aug 24, 2005 11:40 am
It is even easier than the example posted above.
for line in file('foo.bar'):
    print line
file (which is a synonym for open) support iterators and it yields a class which simply passes records back to you one at a time.
The example posted above would read the whole file into memory in the readlines() function which might be a performance problem for large files.
overflow
overflow
Postby overflow » Wed Aug 24, 2005 12:00 pm
Python doesn't have the equivalent of the Perl <> operator but it's easy enough to reproduce it. Here's a simple cat program written in Python which supports multiple filenames on the command line and '-' for stdin.
#! /usr/bin/python
import sys
def fileargs():
   for filename in sys.argv[1:]:
      if filename == '-':
         for line in sys.stdin:
            yield line
      else:
         for line in file(filename):
            yield line
for line in fileargs():
   print line
The fileargs function is an iterator (or generator, I can't remember the difference) and passes back records from each input file in turn. It switches to stdin if '-' is specified.
I hope that helps.
overflow
overflow
Postby PhilC » Tue Oct 04, 2005 12:51 pm
Thanks overflow,
That was a very insightful answer and a great example to demonstrate.
(Still wondering why people prefer to use this to perl though)
PhilC
Postby nelz » Tue Oct 04, 2005 1:01 pm
Because the code doesn't look like line noise :)
