Firefox question in both Windoze and Linux...
Goto page 1, 2  Next
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS
Bazza
PostPosted: Sun Oct 31, 2010 7:11 pm    Post subject: Firefox question in both Windoze and Linux... Reply with quote
Hi goons...
This is an odd request about the pull down menu in the
"address" bar....
An example two addresses in this pull down menu:-
Google
http://www.google.co.uk/
Linux Format | The #1 source for Linux
http://www.linuxformat.com/
How do I get rid of the........
"Google"
"Linux Format | The #1 source for Linux"
........And other similar useless information for other
addresses?
TIA...
73...
Team AMIGA...
PostPosted: Sun Oct 31, 2010 9:09 pm    Post subject: Reply with quote
Right clicking on individual entries in Firefox drop-down menus offers me a Delete option. Is this not available?
Or do you need Bookmarks>Organise bookmarks which has a Delete option?
Or do need History>Show all history which allows you to delete individual entries?
Bazza
PostPosted: Sun Oct 31, 2010 9:32 pm    Post subject: Reply with quote
Hi jh...
Thanks for replying...
I think you misread my post, I still want the addresses NOT
the cryptic crap that goes with them. I know what the
addresses are and don`t have to be told by Firefox hence
my post...
In essence I don`t want to delete any address just the cryptic
crap above each one...
73...
Team AMIGA...
PostPosted: Mon Nov 01, 2010 7:33 am    Post subject: Reply with quote
I suspect the answer is change to Chrome - or possibly Chromium which doesn't show any of this.
Konqueror does but as a second column, not below the url; so your eye is not caught by them
PostPosted: Mon Nov 01, 2010 5:21 pm    Post subject: Reply with quote
How very silly that you don't think to use the "edit" option in organising bookmarks just click the link and the "name" option holds that guff,edit it and Bob's your aunty's husband Wink
Bazza
PostPosted: Mon Nov 01, 2010 6:26 pm    Post subject: Reply with quote
Hi towy71...
Thanks but......
Er, right, however I want it to be global, even on NON
bookmarked addresses.
Over to you... ;o]
73...
Team AMIGA...
ajgreeny
PostPosted: Mon Nov 01, 2010 8:30 pm    Post subject: Reply with quote
I am certain there is an add-on that can do that for firefox, which I have used in the past, but I can't find it now; perhaps it is not compatible with FF 3.6.*
MartyBartfast
PostPosted: Mon Nov 01, 2010 9:04 pm    Post subject: Reply with quote
Try this
https://addons.mozilla.org/en-US/firefox/addon/6227/
[url][/url]
Bazza
PostPosted: Mon Nov 01, 2010 9:36 pm    Post subject: Reply with quote
Hi MBF...
Not perfect, but miles better than the original layout.
Thanks a lot... :)
73...
Team AMIGA...
MartyBartfast
PostPosted: Mon Nov 01, 2010 9:55 pm    Post subject: Reply with quote
Bazza wrote:
Hi MBF...
Thanks a lot... Smile
I think there are others which do similar things, so might be worth browsing some of them.
PostPosted: Tue Nov 02, 2010 9:47 am    Post subject: Reply with quote
I'm sure that you can do it by typing
Code:
 about:config
in the address bar and scrolling through but it warns "Here be dragons" and I'm too timid to mess with that Wink
Bazza
PostPosted: Tue Nov 02, 2010 6:15 pm    Post subject: Reply with quote
Hi towy71
> "Here be dragons" and I'm too timid to mess with that ;)
Ooooh, that looks fun... :)
Already had a quick gleg and ooooh many ways to crash
my browser... :D
Will take a proper look later...
Thanks for that snippet...
73...
Team AMIGA...
PostPosted: Tue Nov 02, 2010 7:24 pm    Post subject: Reply with quote
I'd already had a search in about:config using "address" and "location" as search terms without turning up anything useful, which is why I hadn't bothered to mention it.
Thinking about it again, I have used "url" as a search term. This turns up some things that look as though they might do something, but if the default string associated with a value is "+", for example, what are the alternatives and what do they do? Ho hum. I think the add-on looks a much simpler way of doing things, I wonder exactly what they change to achieve the effect?
ajgreeny
PostPosted: Tue Nov 02, 2010 9:25 pm    Post subject: Reply with quote
MartyBartfast wrote:
Try this
[url][/url]
Thanks for that MartyBartfast. I looked for it but could not find it, and could not remember what it was called.
PostPosted: Wed Nov 03, 2010 10:45 am    Post subject: Reply with quote
In the Bookmarks menu choose "Organise Bookmarks" - the resulting box shows the tree structure on the left of all your bookmarks. When you select a bookmark folder on the left, each bookmark is displayed on the top right panel. Select a bookmark there and then edit in the dialogue boxes below - names and addresses can be edited.
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS All times are GMT
Goto page 1, 2  Next
Page 1 of 2
