As an addendum to my Python freebie code below...
Postby Bazza » Fri Oct 01, 2010 7:25 pm
Hi all...
I mentioned at the end if it was possible to create a real time
audio oscilloscope and the answer seems to be YES. WOW!!!
Now I would like some help from the Linux geeks on here...
The code below is STANDARD Python, (2.5.2), and records
sound from the mic input at the moment.
Only a default Python install is required - no special
dependancies.
It takes about 8 seconds to record then after that it
immediately plays back the recording.
Would you give it a test. You might need to raise your
voice into the mic but hey that is no big deal.
Name the code below as record.py and save in the Python`s Lib drawer. As soon as you "import record[RETURN/ENTER]"
talk loudly into the mic for about 8 seconds or so.
So please humour me and give it a test as I could make
a calibrated audioscope from it. Reply back on here...
ENSURE that the sound card is NOT in use by another
application.
# Test code for record and playback.
# import sys
# import os
def main():
    global record
    record=""
    # Record from my laptop`s mic.
    # Note sample rate unknown at the moment, (8KHz?).
    # Shout into the mic` for test purposes.
    audio=file('/dev/audio', 'rb')
    record=audio.read(65536)
    audio.close()
    # Playback from the sound card.
    audio=file('/dev/audio', 'wb')
    audio.write(record)
    audio.close()
main()
TIA...
EDIT:
I forgot to add:-
If it doesn`t seem to work properly after "import"(ing) rerun
the code as "record.main()[RETURN/ENTER]" and all will be
well. I forgot that it can take a little time for the "pyc" bytecode to be generated on the VERY first attempt...
73...
Team AMIGA...
Bazza
Postby ScannerDarkly » Sat Nov 06, 2010 1:18 am
Why are the import lines 2-3 commented out?
Linux since Ubuntu 6.06.
ScannerDarkly
Postby Bazza » Sat Nov 06, 2010 7:58 am
They are not needed, and........
I quirk of mine...
I always make sure that......
import os
import sys
......are ready for my usage to remind me and are commented
out for this reason. They are the first two lines of a standard
page that I use when coding.
In this case I will be using this idea to get "real time" data
from audio input for an audio oscilloscope, (playing back is
unimportant to me ATM).
How I display this on screen using text mode will be uploaded
too when I have worked out the method.
IF those two imports are required for these two events then
they are there so that I don`t forget.
They are probably the two most important imports that I use.
73...
Team AMIGA...
Bazza
