PHP Coding Academy - request for Hudzilla
Postby chriswadams » Sat Jul 31, 2010 9:17 pm
Hey Paul --
I'm working on Project 2, and I really messed up on step 2. Would you mind posting the full, final source code, so I could have a look at it?
Thanks,
chriswadams.
chriswadams
Postby Ram » Sat Jul 31, 2010 10:12 pm
Post your code Chris.
Postby chriswadams » Sun Aug 01, 2010 1:39 am
Here is what I have:
<html>
<body>
<?php
   if(isset($_POST["user_input"])){
      $input=$_POST["user_input"];
      //don't try to load the saved_feeds file if it doesn't exist!
      if (file_exists("saved_feeds")){
         $feeds=file_get_contents("saved_feeds");
         $feeds=explode("\n", $feeds);
         if(!in_array($input, $feeds)){
            //it's a new feed!
            file_put_contents("saved_feeds", "$input\n", FILE_APPEND);
      }else{
      file_put_contents("saved_feeds", "$input\n");
      $feed = simplexml_load_file($input);
      $titles = $feed->xpath("//item/title");
      foreach ($titles as $title){
         print "<p>$title</p>";
<form method="post" action="project2.php">
<input type="text" name="user_input" />
<input type="submit" />
</form>
<?php
      foreach ($feeds as $feed){
         echo "<p><a href=\"$feed\">$feed</a></p>";
</body>
</html>
Mainly, I'm confused about the ' if (file_exists("saved_feeds")){ ' block of code. On p. 39 of the 'Coding Academy', Hudzilla indicates that it goes toward the end of the script, but on p. 42 he indicates that it goes at the top ... or perhaps both. I don't know whether the redundancy is right or wrong. I have tried all three possibilities with no results.
Note that the script worked prior to adding in that block on p. 39, but as it is now, it doesn't do anything. This makes me think I have also somehow messed up the syntax, maybe leaving out a semicolon or parenthsis somewhere, but I can't find it. If you can spot it, I would be grateful.
Thanks,
chriswadams.
chriswadams
Postby nikkius » Wed Aug 04, 2010 2:21 pm
I think the problem with your code is a curly bracket (or brace) in the wrong place.
you have:
   }else{
and you have at the end of the first block of php:
Should be:
   }else{
and should be at the end of the first block of php:
As to the ' if (file_exists("saved_feeds")){ ' block of code,
page 39 is to display the list of previously entered feeds in the browser if the saved list exists, page 42 is about checking the saved file exists, if not create it and don't add duplicate entries to the saved file, and get rss feed list from the site the user entered and display the titles.
The 'display titles' bit only works for me when entering http://www.tuxradar.com/rss but that may just be because I don't know any other rss feed url's that conform to the code.
hth
nikkius
Postby Ram » Wed Aug 04, 2010 3:47 pm
Well spotted.
Postby chriswadams » Wed Aug 04, 2010 10:33 pm
Hi, Ram & nikkius:
That was well spotted nikkius. And you were right, moving the brace fixed that part of the problem.
What remained was that the resulting headlines weren't printed as hyper-text. By placing this line --
print ("Testing ...");
-- in the second code block, and adding this --
echo "<p><a href=\"$title\">$title</a></p>";
-- to the first code block, I discovered that the script was completely ignoring the second block. Is it supposed to do that?
The second change above, produced clickable links, although strangely, none lead to any feeds.
Anyway, thanks for the help, guys!
chriswadams.
chriswadams
