Continue execution of bash script while in listening state
Postby leke » Wed May 26, 2010 7:51 pm
I wanted to automate a fairly long shell script process that kind of falls in to a listening state and then would need to open another window and execute another command. Problem is, I don't know how to run other commands after that state is reached.
Any tips?
Thanks.
Here is the script if you are interested...
hciconfig reset
sdptool add --channel=2 SP
# Connect phone's bluetooth console to PC then...
rfcomm listen rfcomm2 2
# Connection is made. Process is ongoing.
# This would open new terminal if the last command wasn't still running.
gnome-terminal -e 'cu -l /dev/rfcomm2'
leke
Postby nelz » Wed May 26, 2010 8:07 pm
You could use a fifo, which works rather like a pipe but looks like a file. Something like
mkfifo /tmp/myfifo
command1 >/tmp/myfifo &
cat /tmp/myfifo | while read stuff; do
    process stuff
    done
The & on command1 backgrounds the process. Then your loop runs until command1 exits and it has read all data in the pipe.
Postby leke » Fri May 28, 2010 12:04 pm
Thanks. I've still trying to understand how it works, but thanks for the info :P I'll do some googling on the subject ;)
leke
