Coding Academy Project 2 Aspell problem
Ozram
PostPosted: Tue Apr 20, 2010 9:21 am    Post subject: Coding Academy Project 2 Aspell problem Reply with quote
When I run the command to dump the word list from Aspell into a file I get the following error message:
rod@Dylan:~/Projects/WordScramble/WordScramble/bin/Debug$aspell dump master|sort|uniq>wordlist
Error: The file "/usr/lib/aspell/en_AU" can not be opened for reading.
There is no en_AU in the aspell directory.
It looks to me like the command is trying to find an Australian version of the dictionary.
Thinking it might be hidden from me I tried chmod while in the aspell directory:
rod@Dylan:/usr/lib/aspell$ sudo chmod u+r en_AU
chmod: cannot access `en_AU': No such file or directory
Any help at all would be appreciated.
Coll
PostPosted: Tue Apr 20, 2010 9:22 pm    Post subject: Reply with quote
en_AU is not a command but a language setting.
look for the variable set to en_AU by this command:
set | grep en_AU
and try setting that to en_US for now.
I'd say that aspell is set up in en_US. A better solution would be to install aspell in en_AU, but don't know if that option is available.
JohnMac
PostPosted: Wed May 05, 2010 11:31 am    Post subject: Reply with quote
I am having the same problem- maybe it is due to the southern latitude!
Have run the following with result shown
john@john-desktop:~/Projects/WordScramble/WordScramble/bin/Debug$ aspell dump master |sort|uniq>wordlist
john@john-desktop:~/Projects/WordScramble/WordScramble/bin/Debug$ set | grep en_AU
GDM_LANG=en_AU.UTF-8
LANG=en_AU.UTF-8
My knowledge of Terminal is severely lacking as to what action I should take to take the action suggested of changing the setting.
Help would be appreciated.
Coll
PostPosted: Wed May 05, 2010 7:49 pm    Post subject: aspell Reply with quote
Try the following:
set LANG=en_US.UTF-8
set LANG=en_AU.UTF-8
This is an educated guess, not something I have actually tried.
Alternatively, possibly there is an option in aspell (try "aspell --help" ?) to tell it to do it in english-US. Or maybe there is an option to install the AU dictionary with real words for aspell. If you are on a Red-Hat based machine eg Centos try
yum list aspell
and look for a something claiming to be an australian dictionary then do a
yum install _______(au dictionary)
JohnMac
PostPosted: Fri May 07, 2010 11:09 am    Post subject: Problem with aspell Reply with quote
Tried the forgoing without success, however, a bit of lateral thinking along the lines of AU representing our version of the English dictionary led to using System Administration -> Language Support changing the Dictionary to English (United Kingdom) but had to stick with the US text for dollar sign!
This appears to have done the trick & I now have a wordlist file to work with.
I should be able to go back to our dictionary now.
