Pretty slick, huh? (No!)
Postby overflow » Tue Sep 13, 2005 5:44 pm
Unfortunately, in my work, I come into constant contact with Windows, which I find increasingly troublesome. Today, I needed to find out who a SID belonged to. A SID, if you don't know, is a complex string that uniquely identifies a user - globally. A bit like uid numbers in Unix.
Anyway, I needed to find the owner of a SID and so after a bit of a hunt, I came across this on MS TechNet's Script Guy site which, although back-to-front, would allow me to get there.
Technet wrote:
strComputer = "."
Set objWMIService = GetObject("winmgmts:\" & strComputer & "\root\cimv2")
Set objAccount = objWMIService.Get _
    ("Win32_UserAccount.Name='kenmyer',Domain='atl-ws-01'")
Wscript.Echo objAccount.SID
Pretty slick, huh?
No!
Absolutely horrible!.
What a revolting, unmemorable, twisted mess.
Try this:
grep "^kenmyer:" /etc/passwd
Which is slicker, Script Guy?
overflow
overflow
Postby M0PHP » Tue Sep 13, 2005 6:59 pm
But you could argue that "Wscript.Echo objAccount.SID" gets the actual SID, whereas the grep command you quoted gets the whole line of the *nix username.
M0PHP
Postby nelz » Tue Sep 13, 2005 8:14 pm
grep ^kenmyer: /etc/passwd | cut -d: -f3
although it's even easier with
id -u kenmyer
Return to Discussion
