reCAPTCHA
bobthebob1234
PostPosted: Wed Jan 20, 2010 6:32 pm    Post subject: reCAPTCHA Reply with quote
I would like to add a captcha to a form I have (which sends emails...) However it works in IE (6) but not firefox (on ubuntu & winblows)...
here is some code
Code:
 <form action="new.php" method="post" name="form">
<?php
require_once('recaptchalib.php');
$publickey = "(deleted)";
$privatekey = "(deleted) ";
# the response from reCAPTCHA
$resp = null;
# the error code from reCAPTCHA, if any
$error = null;
# are we submitting the page?
if ($_POST["submit"]) {
   $error_count=0;
   echo '
     <tr>
     <td colspan="2" class="errors">
   Checking
   </td>
  $resp = recaptcha_check_answer ($privatekey,
                                  $_SERVER["REMOTE_ADDR"],
                                  $_POST["recaptcha_challenge_field"],
                                  $_POST["recaptcha_response_field"]);
  if ($resp->is_valid) {
    echo "<tr><td colspan=\"2\" class=\"errors\">You got it!</td></tr>";
    # in a real application, you should send an email, create an account, etc
  } else {
    # set the error code so that we can display it. You could also use
    # die ("reCAPTCHA failed"), but using the error message is
    # more user friendly
    $error = $resp->error;
   $error_count++;
    echo '<tr><td colspan="2" class="errors">The captcha was incorrect. ' . $error . '</td></tr>';
  if ($error_count > 0) {
      $s ="";
      if ($error_count > 1) {
         $s = "s";
       echo "<tr><td colspan=\"2\" class=\"errors\">There was $error_count error$s. Please correct these and try again.</td></tr>";
and
Code:
<fieldset><legend>Captcha</legend>
Please enter the two words below.
<?php
echo recaptcha_get_html($publickey);
      </fieldset>
If i echo $_POST["recaptcha_challenge_field"], in firefox it is blank and in ie it has lots of random letters and hashs,etc
Any ideas why this would be, and how to fix it?
Thanks
PostPosted: Wed Jan 20, 2010 7:10 pm    Post subject: Reply with quote
phpBB3 has a working Cotcha environment, why not 'nick' their code? Wink
PostPosted: Thu Jan 21, 2010 10:18 am    Post subject: Reply with quote
reCAPTCHA supply the code required for free - no need to "nick" the code because it is free.
I haven't had any problems with reCATCHA, I've just included the code at http://recaptcha.net/plugins/php/. Point "3" goes at the top of your page. You make the page containing the form a PHP page and the code at point "4" goes on your form processing page (also PHP).
Note: I have deleted the public and private keys from your code posting, you don't want to give the private one out Wink
bobthebob1234
PostPosted: Thu Jan 21, 2010 6:22 pm    Post subject: Reply with quote
opps thanks.
I'll try coping and pasting that code (again...) (although i did use the example first...)
PostPosted: Thu Jan 21, 2010 6:26 pm    Post subject: Reply with quote
Which is why I put it in ' marks Razz
bobthebob1234
PostPosted: Thu Jan 21, 2010 6:41 pm    Post subject: Reply with quote
Something else in the page must be breaking it. Have tried new code and still not work. However copied example code to new page it all is good.
I also regenerated the keys.
bobthebob1234
PostPosted: Thu Jan 21, 2010 7:05 pm    Post subject: Reply with quote
I think it doesn't like tables in tables. Got it to work now (for the moment!). Thanks to all.
