Windows BSODS :( but Linux works :)
Postby pctechie » Sun Dec 27, 2009 1:24 pm
Okay i have had two bsod's from windows xp sp2, memory_management and pfn_corrupt_list, now i have tried everything, safe mode, reboot, reset bios, clean pc, clean ram slots, re insert memory modules, but to no avail,
I have ran memory test no problems :), my Ubuntu works, everything apart from windows :( I think its a driver issue, but i can't correct this as i cannot access safe mode, my only option left is to reinstall xp sp2, but i hope i don't have to, although its looking like the only solution, any other suggestions? to help sort out this problem :?:
Thanks in advance :D
pctechie
Postby wyliecoyoteuk » Sun Dec 27, 2009 10:34 pm
Well, if Linux works, not a Linux or hardware issue, so just Windows.
You would probably do better posting this on a Windows forum.
Few of us are Windows experts.
Re: Windows BSODS :( but Linux works :)
Postby ollie » Mon Dec 28, 2009 9:27 am
pctechie wrote:Okay i have had two bsod's from windows xp sp2, ...
Upgrade to SP3, that is the only version supported by Microsoft now.
Postby Bazza » Mon Dec 28, 2009 11:23 am
Hi pctechie...
> ........but i can't correct this as i cannot access safe
> mode........
What?
Contiuously tapping F8 from coldboot does not bring up
the Windows selection screen in Video Mode 3?
Have you got the 6 floppy disc repair set and a floppy
drive internal or external?
73...
Team AMIGA...
Bazza
Postby pctechie » Mon Dec 28, 2009 1:07 pm
Let me clear things up i could select safe mode but i just got a BSOD when loading, and i tried to repair windows major fail, got errors when i booted in windows, so i just did a fresh install :D
And with vista i just can't be bothered updating 24/7 in win 7 updating is managed better, and with me having built my PC, there are hardware issues left, right and center, but in 7 there isn't as many if none, most of the time :)
pctechie
Postby Ram » Tue Dec 29, 2009 11:14 am
Can you use the recovery console via CD. If so try a chkdsk /f
when trying safe mode what is the last driver listed before the BSOD? or What is the first part of the BSOD msg?
