rcayea
Posted: Sun Nov 08, 2009 11:56 pm Post subject: LXF124 Power up Linux Ubuntu Problem |
Hi everyone,
As I read and try the power up linux tips from the LXF124 issue, and I go to try them in my Ubuntu 9.10 64 Bit computer, it seems that Ubuntu has a different setup than what the magazine suggests I am able to do.
For example, on page 41 it says to try the following with root privileges, /boot/grub/menu.1st. OK I tried that to speedup boot time which is the tip suggested, and Ubuntu doesn't seem to have that file any more. What to do?
Also, to speed up boot time I tried with sudo, "/etc/init.d/rc" so I could run boot boot processes in parallel and that doesn't seem to exist either.
Any thoughts?
Thanks,
Randy |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1570 Location: Guisborough
Posted: Mon Nov 09, 2009 12:07 am Post subject: |
Ubuntu 9.10 as moved to using grub2 which uses grub.cfg WHICH SHOULD NOT MANUALLY EDITED. This is totally different from the previous grub which used menu.lst.
I believe 9.10 as also moved away from using init scripts. _________________
rcayea
Posted: Mon Nov 09, 2009 1:39 am Post subject: |
In that case, if Ubuntu has changed so much here is my thought(s)...
I bought the magazine (from newsstand) thinking I could take advantage of the tips/suggestions.
I have been reading LXF for about a year not and I know Ubuntu gets creamed for getting so much press in LXF, but being the most popular distro, does LinuxFormat have any intention of posting how to use these tips for the new Ubuntu? I would like to get my 18 dollars (Live in DC, USA area) worth from the magazine.
Thanks,
Randy |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3369 Location: Birmingham, UK
Posted: Mon Nov 09, 2009 9:55 am Post subject: |
As Ubuntu 9.10 was actually released after the magazine went to print, that is a little unfair.
Lead times on articles mean that the latest "cutting edge" release will not be covered immediately, and as most Ubuntu users are on 9.04 or earlier, it would not be appropriate either. _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
rcayea
Posted: Mon Nov 09, 2009 10:39 am Post subject: |
Unfair, maybe. I give you that.
However, if you are going to say that most Ubuntu users are using 9.04 or earlier you probably should post the concrete data you are making such a conclusion from. Besides, I am only guessing here, but LXF probably fiddled with the release candidates and the beta released. I do believe they put a beta release or something on one of their earlier magazine disks. So, they might have seen the changes for 9.10. That is just a guess and I will now stop guessing.
In my effort to reword my previous post, I simply would like to take advantage of the tips provided by LXF. I should ask nicely, could you (LXF) maybe post a 9.10 version of a couple of your tips? |
Marrea LXF regular
Joined: Fri Apr 08, 2005 10:32 pm Posts: 1846 Location: Chilterns, West Hertfordshire
Posted: Mon Nov 09, 2009 11:32 am Post subject: |
I for one am really hoping Paul will consider including an in-depth article about grub2 in the near future. As far as I am concerned, this is a whole new ball game and I would appreciate some expert advice.  |
Posted: Mon Nov 09, 2009 12:01 pm Post subject: |
| rcayea wrote: | Unfair, maybe. I give you that.
However, if you are going to say that most Ubuntu users are using 9.04 or earlier you probably should post the concrete data you are making such a conclusion from. Besides, I am only guessing here, |
We are both guessing, maybe I should have put a "probably" in there.
Some people move to the latest release straight away, others wait for the dust to settle and the cries of pain to fade, and yet others are still asking questions on the Ubuntu forums about 6.04.
It could also be the case that the changes (improvements?) to grub have made the tips obsolete. _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
Ram LXF regular
Posted: Mon Nov 09, 2009 1:44 pm Post subject: |
| wyliecoyoteuk wrote: |
It could also be the case that the changes (improvements?) to grub have made the tips obsolete. |
For grub that would not be the case as the default setting for the grub menu is 10 seconds.
I believe that Start up Manager works with GRUB2 and it is possible to set the menu to 1 second.
As for the init scripts I believe that 9.10 new approach is faster, so wyliecoyoteuk is right in that the tips would now be obsolete. _________________
rcayea
Posted: Mon Nov 09, 2009 3:34 pm Post subject: |
Hey Everyone,
Thanks for not turning this into a he said/she said kind of thing or an argument.
So lets just hope we get some good advice from the fellows at LXF.
Thanks,
Randy |
ajgreeny LXF regular
Joined: Wed May 10, 2006 9:18 pm Posts: 413 Location: Oxfordshire.
Posted: Wed Nov 11, 2009 12:44 am Post subject: |
| Ram wrote: | | wyliecoyoteuk wrote: |
As for the init scripts I believe that 9.10 new approach is faster, so wyliecoyoteuk is right in that the tips would now be obsolete. |
Yes, a few of the things that startup manager does still work with grub2, but most tweaks that were possible are no longer possible with SUM. So far I have not got to grips with grub2 and don't use it. I have ubuntu 9.10 on a testing partition and installed grub to it's own disk instead of my main (ubuntu 9.04) OS disk's MBR. I then simply added 9.10 to the menu.lst of 9.04 and use grub from that OS.
No doubt grub2 will eventually become second nature to me as is legacy grub, but it is much more difficult to configure if you have two disks and 4 OSs, as I have, and don't want the grubmenu to be as long as a novel. _________________ Xubuntu 12.04 user, and loving it! |
