Loggin Help
Loggin Help
Postby iancass » Thu Sep 01, 2005 7:09 pm
Cant believe I am asking for help here about this problem but for some reason after successfuly installing Lunix Mandrive 2005 ltd edition I come to a point where its asking me for a user name and password after it ahs booted up etc. When doing installation I made a point of only entering a password and not a user name. Is there an easy solution?
iancass
RE: Loggin Help
Postby Rhakios » Thu Sep 01, 2005 8:05 pm
Enter root as the username, give your root password, then create a new user with a name, or if userdrake shows a no-name user, try editing that one to give the user a name.
RE: Loggin Help
Postby iancass » Fri Sep 02, 2005 7:55 am
So am I right in saying that were it asks for my Username I enter "root", then tab down to Password & enter what ever my Password is, Then it will ask me to create a username?
iancass
RE: Loggin Help
Postby linuxgirlie » Fri Sep 02, 2005 8:25 am
No,
What will happen is it will log you into the system. You then have two choice you can use a graphical menu to edit your user or you can create one via the console. For graphical go -> Start Menu -> System -> Configuration -> Other and then User Administration.
For the console way open a console/konsole type useradd usernamehere
and then type passwd usernamehere logout and in with your new user!! :D
linuxgirlie
RE: Loggin Help
Postby iancass » Fri Sep 02, 2005 8:44 am
Thanks all for info
iancass
