Slow broadband....
Postby RD » Tue Aug 23, 2005 10:47 am
yea
RD
Postby Dark_Willow » Tue Aug 23, 2005 9:59 pm
Have adjusted the piplining setting in FireFox, which has made it noticably faster when it comes down downloading data fromm sites, but it is still taking forever to actually look up web addresses. Looking in the modprobe.conf file I didn't find any lines referring to IPv6 at all. See below for file details:
# This file is autogenerated from /etc/modules.conf using generate-modprobe.conf command
alias eth0 usbnet
alias sound-slot-0 snd-maestro3
install scsi_hostadapter /sbin/modprobe ata_piix; /bin/true
remove snd-maestro3 /sbin/modprobe -r snd-pcm-oss; /sbin/modprobe --first-time -r --ignore-remove snd-maestro3
install snd-maestro3 /sbin/modprobe --first-time --ignore-install snd-maestro3 && { /sbin/modprobe snd-pcm-oss; /bin/true; }
install usb-interface /sbin/modprobe uhci-hcd; /bin/true
Dark_Willow
Postby Dark_Willow » Wed Aug 31, 2005 7:37 pm
Any ideas on anything else I can try to solve this lag in site lookup?
Dark_Willow
Postby jer1ch0 » Thu Sep 01, 2005 10:45 pm
jer1ch0
