Boot sequence
Boot sequence
Postby fishphone » Mon Aug 22, 2005 3:40 pm
Is it possible to increase the length of time that my dual boot options screen displays for before booting to the default option? It is set at about 3 seconds after which the default os is booted. If possible how can I do it please?
fishphone
RE: Boot sequence
Postby M-Saunders » Mon Aug 22, 2005 3:46 pm
First, find out if which boot loader you're using -- it'll be either LILO or GRUB.
If it's LILO: change to the root user, edit the /etc/lilo.conffile and edit the 'timeout' line to something higher. Then run /sbin/lilo afterwards to update.
If it's GRUB: edit /boot/grub/menu.lst or /boot/grub/grub.conf and change the 'timeout' line.
Next time you boot, it should take as many seconds as you set it to.
M
M-Saunders
RE: Boot sequence
Postby fishphone » Fri Aug 26, 2005 5:54 pm
Thanks for your advice M. When I try to access /boot/grub/menu.lst using gedit I get an access is denied dialogue. I am the only user of the machine so as far as I know I should have unlimited access. Any ideas please?
Steve
Programming today is a race between software engineers striving to build bigger and better programs, and the Universe trying to build bigger and better idiots. So far the Universe is winning!!!
fishphone
RE: Boot sequence
Postby jdtate101 » Fri Aug 26, 2005 6:05 pm
you need to be root to edit this file
Ubuntu Edgy & Beryl on:
AMD X2 4800+
4GB Corsair TWINX RAM
2 x Seagate 400GB USB2
Dual Layer DVD-RW
Nvidia 7800GT
2 x Viewsonic VP201b TFT
Iomega Rev Internal
jdtate101
RE: Boot sequence
Postby fishphone » Fri Aug 26, 2005 6:15 pm
How do I log on as root please? In the terminal window the command line shows osername@localhost. I presume i need to change the localhost bit to root, but forgive me as you can probably tell I am completely new to Linux so not sure how to do this.
Steve
fishphone
RE: Boot sequence
Postby nelz » Fri Aug 26, 2005 9:11 pm
In the terminal, type:
su -
[give root password when asked]
gedit /boot/grub/grub.conf
The first command makes you root, everything you do in that terminal is then done as root until you logout (press Ctrl-D).
RE: Boot sequence
Postby fishphone » Sat Aug 27, 2005 9:13 am
Thanks nelz that worked a treat. Now I actually have enough time to select Linux to boot when I wish. Do you have any recommendations for books on the basics of Linux because I am having 'fun' trying to work out how to do things which seem quite different from my other os (which I daren't mention here!!!)?
Thanks again
Steve
fishphone
RE: Boot sequence
Postby towy71 » Sat Aug 27, 2005 10:15 am
for a tree killer there is: Linux in a Nutshell I
online try: the Linux documentation project
HTH
Dick
RE: Boot sequence
Postby jjmac » Sat Aug 27, 2005 10:23 am
It's ok to mention it if you like, [horrors.png] ;) :)
http://counter.li.org
RE: Boot sequence
Postby ollie » Sat Aug 27, 2005 10:44 am
In PDF format there is a number of guides at The Linux Documentation Project - Guides that you can download to peruse at one's leisure. You may also be interested in Linux Newbie Administrators Guide.
See you don't have to kill all the koala homes for good learning resources :mrgreen:
RE: Boot sequence
Postby fishphone » Sat Aug 27, 2005 3:16 pm
Thanks for all the suggestions from the guys down under. Are you watching the cricket?
fishphone
RE: Boot sequence
Postby towy71 » Sat Aug 27, 2005 3:23 pm
now that was cruel fishphone ;-) :lol: :oops: hahaha
RE: Boot sequence
Postby fishphone » Sat Aug 27, 2005 3:44 pm
Well it doesn't happen very often does it? 161 for 4
fishphone
RE: Boot sequence
Postby ollie » Sun Aug 28, 2005 2:56 am
They just got told to make the series interesting after the one dayers and first test - something about gate takings, advertising rights, collapse of cricket if they keep beating teams in three days, TV rights (no-one in Australia wanted to broadcast this tour - it's being shown on the 5th (out of 5) free to air channel - the SBS multicultural channel) and other money factors.
At least it is creating some interest in the UK tabloids - they published the picture of the Aussies with handbags - but then to Poms got beat in the final by the same team when it really counted. :wink: :lol:
RE: Boot sequence
Postby jjmac » Thu Sep 01, 2005 12:16 am
totally random (grin)
