How To Increase Screen Resolution with VirtualBox and Ubuntu
Postby udroomla » Mon Jul 30, 2007 4:14 pm
I have solved the problem of lack of usable choices of screen resolution when operating "Ubuntu" inside "virtual box" (which is running on your windows PC - as rolled out with the DVD from Linux Format Mag "Building a great website"). It was annoying to not be able to operate the Virtual Box window at my 1680x1050 resolution.
The clue was in reading the pdf that came with VirtualBox (or view the help file contents in Virtual box). Reading section 4 talks about "guest additions" which need to be installed to enable better video resolutions and other stuff. It seems hard at first if you don't know linux (like me) but here are some simple instructions.
1. Start Virtual box and log into Ubuntu.
2. Hit the right ctrl key so you can get your mouse pointer outside the virtual machine.
3.Go to top of virtual window, click on devices then select "Install Guest Additions"
You will see a window pop up inside Ubuntu showing you that there are some new files mounted in a virtual CDROM drive. One of those files should be VBoxLinuxAdditions.run
You must run the file with some admin permissions so do that this way...
4. Click inside the Ubuntu screen again then go to Applications - Accessories then Terminal. The terminal window is where you will run the file from, but first we must navigate to the correct directory.
5. type this... cd /media/cdrom0 (then hit enter, there is a space after cd!)
6. next type... dir (You should see amongst the files displayed VBoxLinuxAdditions.run)
7. now type... sudo sh ./VBoxLinuxAdditions.run (yes, that is a full stop before the slash!)
after you hit enter and it has done its stuff, the files are now accessable from Ubuntu.
8. You now need to reboot the virtual machine or press Ctrl+Alt+backspace.
9. Log onto the Ubuntu desktop and this time go to System - Preferences then Screen Resolution. You should now have more options than the three low res options you had at the beginning of the day!
If you are happy then H.A.N.D (have a nice day)... otherwise...
Still not happy because your favourite resolution is not one of the newly listed ones then follow these steps...
1. Open the terminal window again (Applications - Accessories then Terminal)
2. Type... sudo gedit /etc/X11/xorg.conf (space after gedit and X11 must be capital X)
3. It will ask you for a password which is the same as you log in with.
4. The text editor loads and you should see a lot of text in the window. First make a backup of this file by going to "file" then "save as" and changing the filename to xorgbak.conf
5. You now need to hunt through the text until you see the display resolutions listed. The ones you will be concerned about will be listed under bit depth 24 or bit depth 16 (as these depths are the ones that give you a large amount of colors.)
6. The idea here is to have your favorite screen resolution included in this list. Do this by either inserting it before the other listed resolutions in the exact same manner or typing it over one of the others. (you will only need to do this for the ones under bit depth 24 and 16)
7. You must now do a "save as" but be careful here as this time we need to call the file xorg.conf again. If you just hit save here you would have saved the changes over the backup file you created!
8. You are done. Hit Ctrl+Alt+Backspace to restart your virtual box, log in and enjoy your new screen resolution options!
Addendum..."Whoops I broke my Ubuntu install and it won't load again!"
If you broke your virtual machine follow these instructions:
1. Start Ubuntu loading and hit escape as soon as you see the "grub" loading screen.
2. Select one of the recovery options and wait for it to load to the prompt.
3. type... mv /etc/X11/xorg.conf mv /etc/X11/xorg1.conf (space after each mv) This is moving and renaming the file xorg.conf
4. You are done (almost). Ubuntu will boot properly next time you try, but you need to follow step 2, 3 and 4 from above, but remember, this time you will be loading the file called xorgbak.conf into the editor and when you go to save, use "save as" and call it xorg.conf :D
udroomla
RE: How To Increase Screen Resolution with VirtualBox and Ub
Postby pjhk » Wed Jun 10, 2009 11:58 pm
udroomla thanks for your post, very helpful!
pjhk
Postby Wolwy » Thu Jun 18, 2009 1:45 pm
Hello,
Thanks for explain that with such details. However I have still a problem. When installing Guest Additions, nothing happens ... and there is not the "VBoxLinuxAdditions.run" on cdrom0, so I can't open it.
My computer is a MacBook, OS 10.5 . Can you help me ?
Wolwy
Postby pkohler01 » Thu Jun 25, 2009 2:25 am
Thanks for the information.
These instructions worked for a 64bit Ubuntu 9.04 virtual machine run on a Windows 7 RC 64bit PC.
pkohler01
Postby philgons » Sun Jul 05, 2009 12:36 am
This doesn't work with VirtualBox 3 on Vista 64-bit running Ubuntu 9.10. The options have been removed. However, it's now much easier. Just resize the VirtualBox window and it will automatically resize to the appropriate resolution.
philgons
Postby rusto » Fri Aug 21, 2009 12:11 am
Since you are on a Mac, you need to use "VBoxLinuxAdditions-x86.run" instead.
Wolwy wrote:Hello,
rusto
Re: How To Increase Screen Resolution with VirtualBox and Ub
Postby JenC » Sun Oct 25, 2009 9:02 am
udroomla wrote:I have solved the problem of lack of usable choices of screen resolution when operating "Ubuntu" inside "virtual box" . . .
Thank you, udroomla, you have both cleared a usage bottleneck for me (the tiny default screens) and taught me some basics of Linux-ing with your clearly written prompts.
Because you were so precise, and because nothing that you wrote was working as advertised, I finally realised the problem was me (surprise!) which led to this Win/Lin/Ubu/tyro finally discovering that on a Mac the enter~Return (new para) key is not the same as the enter key.
It only took 25 years of Mac-ing to discover that, but I think I am finally at lift-off speed for Ubuntu.
FWIW, in the 9.10 x86 rc release the xorg.conf file was quite empty, and after installing the additions just one extra resolution has been added, 1024 x 768, but that is more than large enough to go on with. Even now, there are only very general comments there, and no sizes to modify, but I'll keep poking at things.
Thanks again for your time & care.
Jen
JenC
Nice
Postby sulman » Wed Jul 07, 2010 8:50 am
Worked a charm, very much appreciated.
sulman
Postby arielgenesis » Tue Aug 10, 2010 2:05 pm
This is a very good post but it is slightly outdated unfortunately. I specifically created an account to reply to this thread because it is the 1st on google search.
I am having the same problem, Vista guest, Ubuntu Host, virtualbox, screen resolution.
The problem is, after extensive google searching is that most of the Xorg nowdays does not have xorg.config file anymore. So please if any educated person out there would be very kind to update this piece of very valuable information for the better world, please.
arielgenesis
Postby nelz » Tue Aug 10, 2010 5:33 pm
Xorg still uses an xorg.conf file if it is present[1], it just doesn't need it. Anything you put in this file overrides anything automatically detected, so you can still force the resolution you want in this way.
(1) The current version uses separate files in /etc/X11/xorg.conf.d making it easy to separate the sections of your config.
Postby bobthebob1234 » Tue Aug 10, 2010 7:25 pm
I found that if you install the guest additions on the virtual computer, the resolution adjusts to the window size.
bobthebob1234
If it doesn't seem like this is working
Postby tir38 » Thu Dec 15, 2011 9:58 pm
This is kinda stupid but I spend a long time trying to get the screen resolution to increase. The way Guest Additions works is that it scales the screen resolution based on your window size. So if you are not viewing your Guest Virtualbox in full screen then your Ubunutu list of available screen resolutions won't increase. It wasn't until I put the Virtualbox on full screen before the full screen resolution came up. When I had virtualbox as a small window, I could only ever see 800x600 and 400x300 as screen resolution options.
Silly me.
tir38
Re: If it doesn't seem like this is working
Postby evanjones246 » Thu Feb 16, 2012 9:48 am
There was a recent update that should have solved this issue. you should try updating your software. :)
tir38 wrote:This is kinda stupid but I spend a long time trying to get the screen resolution to increase. The way Guest Additions works is that it scales the screen resolution based on your window size. So if you are not viewing your Guest Virtualbox in full screen then your Ubunutu list of available screen resolutions won't increase. It wasn't until I put the Virtualbox on full screen before the full screen resolution came up. When I had virtualbox as a small window, I could only ever see 800x600 and 400x300 as screen resolution options.
Silly me.
evanjones246
