VCD and MOV/WMV
VCD and MOV/WMV
Postby tedius » Mon Apr 18, 2005 12:19 pm
Does any one know of a good program that will allow me to take a QuickTime movie or a Windows Media Video and convert it into a Video CD.
Tedius
tedius
RE: VCD and MOV/WMV
Postby hairymunky » Mon Apr 18, 2005 10:17 pm
dunno if it will work, but mplayer can encode vid as well as playback...???
hairymunky
RE: VCD and MOV/WMV
Postby fingers99 » Mon Apr 18, 2005 10:28 pm
QT may be a problem, but tovid will knock out a video CD of anything which (your version of) MPlayer will play (which can includes wmv). It's also very easy to use.
Anyone know if there's any libraries available to enable MPlayer to play QT?
fingers99
RE: VCD and MOV/WMV
Postby hairymunky » Tue Apr 19, 2005 7:39 pm
I don't know if QT support is included in the "all" codecs available on the mplayer site...?
Linux powered Astronomy
hairymunky
RE: VCD and MOV/WMV
Postby nelz » Tue Apr 19, 2005 9:26 pm
mplayer -vc help
will list the available codecs.
RE: VCD and MOV/WMV
Postby tedius » Fri Apr 22, 2005 10:30 am
Thanks for the replys I'll be giveing tovid a go over the weekend.
I'll tell you how I got on :)
tedius
Vconverter
Postby otter_d » Sat Apr 23, 2005 4:42 pm
Have you tried the kconverter? look on KDE-apps.org
Should convert to mpeg-1 for you. Once in mpeg-1 K3B can burn it to a VCD easily enough.
otter_d
