KDE
RD
PostPosted: Sat Aug 20, 2005 3:19 pm    Post subject: KDE Reply with quote
Hi
I remember the very first horrible kde Sad today after a lot of umm and arr i updated unbuntu to the new kubuntu thinking well ill have the new kde not much to go by there and all i can say WoW KDE 3.4 is brill i never thought i would see a better KDE than 3.0 though one thing has bugged me im sure some one can tell me how Very Happy that is how do i place the Home and System icons on the desktop ?
Any way other than that i love this version of KDE Very Happy
PostPosted: Sat Aug 20, 2005 3:27 pm    Post subject: RE: KDE Reply with quote
Not sure what you mean by system icon, but the easiest way to get a Home icon on your desktop is to drag it off the K menu onto the desktop and select Copy. Or, create a desktop shortcut that uses the command
kfmclient openProfile filemanagement
so long as your home directory is the default for that profile it will always open in your home directory.
nordle
PostPosted: Sat Aug 20, 2005 4:30 pm    Post subject: RE: KDE Reply with quote
re: the system Icon
Unfortunately, in the version Im running, it appears a little bug means it requires a bit more faff than it should.
1. Right click on desktop, select [create new] --> [Link to Location (URL)]
2. Enter URL as system:
3. Click OK
4. Right Click on newly created icon, select [Propertues]
5. Change URL to be system:/
6. Click OK, and it should be fine.
mugstar
PostPosted: Sat Aug 20, 2005 4:36 pm    Post subject: RE: KDE Reply with quote
Try a desktop shortcut to kcontrol or kinfocenter, they're the nearest to a windows-type 'System' icon.
RD
PostPosted: Sat Aug 20, 2005 5:42 pm    Post subject: RE: KDE Reply with quote
in kde 3.4 (my distro any way) there is a icon called system where it holds home etc on the menu bar where kmenu is i tryed to create a short cut to the home dir using konqueror but not what i wanted Sad
[url=irc://irc.ixl2.org/ixl2]irc.ixl2.org[/url]
nordle
PostPosted: Sat Aug 20, 2005 10:21 pm    Post subject: RE: KDE Reply with quote
RD, is that not what I mentioned above?
I think, therefore I compile
RD
PostPosted: Sat Aug 20, 2005 11:47 pm    Post subject: RE: KDE Reply with quote
Sorry mate need glasses lol
linuxgirlie
PostPosted: Sun Aug 21, 2005 10:00 am    Post subject: RE: KDE Reply with quote
Yeah, I'm not to sure about the system icon, (just installed the latest Mandriva with 3.4 - club members only) I like everything being in 'home' but now when I browse up...argh!!
So good idea for windows people...my parents would love it!! But I might have to get use to using it...or go back to 3.3?!?
Very Happy
Server operating system designed for schools:www.linuxschools.com
coolclassic
PostPosted: Sun Aug 21, 2005 6:11 pm    Post subject: RE: KDE Reply with quote
To get kcontrol back
Edit KDE Menu Editor -> add new Item
name it Kcontrol and put in the field "Command" : kcontrol
, choose a nice icon and save !
Done, Kcontrol is back in KDE menu
The world is your playground why don't you play.
