johnhudson LXF regular
Posted: Tue Feb 03, 2009 7:58 am Post subject: Double log in |
| The last few times I have logged in successfully, when I try to go to a forum, I have to log in again. |
ollie Moderator
Posted: Tue Feb 03, 2009 8:45 am Post subject: RE: Double log in |
| Which browser? Is the browser set to remember passwords? Are you running the browser in "private mode", where the browser clears history and password? |
Posted: Tue Feb 03, 2009 6:05 pm Post subject: RE: Double log in |
| I'm using exactly the same browser, Konqueror, as I have for the past two years and it always remembers the password for me. That is how I log in the first time; then I can access various areas of the site but not the forums without a second login. |
GregS
Joined: Thu Aug 03, 2006 4:54 am Posts: 89 Location: Oz
Posted: Thu Apr 16, 2009 11:38 pm Post subject: RE: Double log in |
Me too!
Something has occurred in the last few weeks that means I have to log in to the LXF site, then again to access the forums (fora?).
This occurs both with M$ XP and IE6 on my work box and Fedora 6 and Firefox at home and occurred simultaneously, without any configuratuion changes that I am aware of on either machine.
Strange! |
nelz Moderator
Posted: Fri Apr 17, 2009 1:12 am Post subject: RE: Double log in |
Are you using the .com or .co.uk address? If you're using the uk address, the Forums link goes to .com, which requires a separate login cookie. The answer is to update your bookmarks to use the .com address. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
GregS
Posted: Wed Apr 22, 2009 5:33 am Post subject: Re: RE: Double log in |
| nelz wrote: | | Are you using the .com or .co.uk address? If you're using the uk address, the Forums link goes to .com, which requires a separate login cookie. The answer is to update your bookmarks to use the .com address. |
Ah! It was co.uk!
Must have meiised where it changed. Thanx |
