-Dave-
Joined: Sat Jan 17, 2009 8:51 pm Posts: 88 Location: St. Helens
Posted: Thu Jan 22, 2009 11:07 pm Post subject: Adobe After Effects Problem - Windows Vista |
Hey, anyone got the foggiest idea why my screen freezes, and goes dotty like this, everytime I try to load Adobe After Effects?
 _________________ With thanks Kenco, my coding nightmares are over! |
Dutch_Master LXF regular
Posted: Thu Jan 22, 2009 11:13 pm Post subject: RE: Adobe After Effects Problem - Windows Vista |
Vi$ta doesn't belong on a Linux forum. Try the 'Other OS' section if you really want to Besides, asking twice in the same place only 1 min later isn't considered 'polite' (but I'll forgive you for that ) |
-Dave-
Posted: Thu Jan 22, 2009 11:18 pm Post subject: RE: Adobe After Effects Problem - Windows Vista |
My bad, I set the post up like 5 hours ago, but had to go afk before pushing Submit. Came back, pushed Submit, had to relog, A blank posting page came up, I hit back in hope that the text is still there, it was, so i pushed submit again.
Also.. The forum is called
Help!
The place to post if you need help or advice.
It doesn't say with what
"Help, I'm a woman trapped in a man's body...GET ME OUT!!!" _________________ With thanks Kenco, my coding nightmares are over! |
Posted: Fri Jan 23, 2009 3:58 am Post subject: RE: Adobe After Effects Problem - Windows Vista |
Yeah yeah.... Be carefull though, or you might end up as 1sf (troll)... (look around here to find that creature... )
towy71 Moderator
Joined: Wed Apr 06, 2005 3:11 pm Posts: 4176 Location: wild West Wales
Posted: Fri Jan 23, 2009 8:33 am Post subject: Re: RE: Adobe After Effects Problem - Windows Vista |
| -Dave- wrote: | It doesn't say with what  | This is the Linux Format Forum and there is a specific "Other OS" forum
Have you been having too many of your avatar  _________________ still looking for that door into summer |
M-Saunders Moderator
Posted: Fri Jan 23, 2009 10:52 am Post subject: RE: Re: RE: Adobe After Effects Problem - Windows Vista |
Moved to Other OS. No worries Dave, but to keep the forums organised we only have Linuxy stuff in Help!
M |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3369 Location: Birmingham, UK
Posted: Fri Jan 23, 2009 5:02 pm Post subject: RE: Re: RE: Adobe After Effects Problem - Windows Vista |
To answer the OP, maybe it's an after effect ?  _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
-Dave-
Posted: Sat Jan 24, 2009 2:45 am Post subject: |
ba dum dum-tssh _________________ With thanks Kenco, my coding nightmares are over! |
ollie Moderator
Posted: Sat Jan 24, 2009 11:11 am Post subject: |
I tried to post on this last night (see my post in "This Website").
How much RAM do you have on the system? Do you have a good (less than 12-months old) graphics card? Is Virtual Memory on a separate hard drive, or partition at the very least? Has the same been done with Adobe's Scratch File location? How many "effects" are being loaded by default into the Library? |
