puffin789
Posted: Thu Apr 07, 2005 7:44 am Post subject: lm_sensors problems needed for 3dfx Voodoo 3 TV-OUT on MDK10 |
I'm trying to install the lm_sensors module under Mandrake 10.0 but it doesn't work. I need this apparently to set up my TV-OUT signel on my 3dfx Voodoo 3 video card.
I find the two packages (liblm_sensors3-2.8.4-1mdk and lm_sensors-2.8.4-1mdk) in Mandrake Control Center, load the DVD (Linuxformat 53 DVD) but then I get an error message saying:
| Quote: | There was a problem during the installation:
unable to install package /mnt/cdrom/Mandrake/RPMS/lm_sensors-2.8.4-1mdk.i586.rpm
unable to install package /mnt/cdrom/Mandrake/RPMS/liblm_sensors3-2.8.4-1mdk.i586.rpm
unable to install package /mnt/cdrom/Mandrake/RPMS/librrdtool0-1.0.46-1mdk.i586.rpm |
I have checked the details of lm_sensors and it is looking for the Linux source tree at /usr/src/linux. Now this seems to be the problem as I don't have such a directory, and when trying to create a symlink (as suggested on the web) I just can't find my Linux source tree at all. What should I look for? Where? I remember that Mandrake has some unusual directory strucutre (I have upgraded this Mandrake 10.0 from a previous version...) Also, how would I make the symlink?
I have also downloaded the lm_sensors module and tried to install manually (though the docs said that I should only "make user" and "make userinstall" with a 2.6 kernel, which I did), but it was looking again for the same directory /usr/src/linux and particularly for the /usr/src/linux/include/linux/autoconf.h file. Now I have searched the whole hard disk and there is no autoconf.h file anywhere...??
I wonder if someone could help me how to install lm_sensors?? I would need this to connect my 3dfx Voodoo 3 card to the TV (to use its TV-OUT functionality).
What more details should I send?
Many thanks! |
puffin789
nelz Moderator
Posted: Thu Apr 07, 2005 9:55 am Post subject: |
| It looks like you may need to install the kernel-source package first. This will put the source in /usr/src/linux-version-number with a link to /usr/src/linux. |
