Web site banner ad
Post new topic   Reply to topic    Linux Format forums Forum Index -> This Website
PostPosted: Tue Nov 18, 2008 4:18 am    Post subject: Web site banner ad Reply with quote
I have a huge problem with the web site. The "ukfast" banner add in the left hand column is the same as the one in the header.
See the screenshot for a better understanding of the problem.
M-Saunders
PostPosted: Tue Nov 18, 2008 9:46 am    Post subject: RE: Web site banner ad Reply with quote
Clearly, the problem is that you're using Windows Smile
Seriously: that's bad. Apologies, although I haven't seen that yet here (Firefox on Linux and Safari on OS X). Has anyone else had that problem?
M
PostPosted: Tue Nov 18, 2008 10:39 am    Post subject: RE: Web site banner ad Reply with quote
Yeah, I was using Windows at work, they get really upset if anything but Windows goes on the network I don't control Wink My old, old boss got really upset when I was demonstrating the lack of security on the network by creating text files called "his_name_was_here.txt" on various servers around the place (state) using a LiveCD (Mepis) with spoofed MAC address, he was watching over my shoulder Very Happy. I was also demonstrating their very inferior filtering service by accessing a site with "Pornography Star" in it's title. Lots of fun! Laughing
Back on my Eee PC and the ukfast ad is the different vertical banner. Don't really know why but I'll have a look tomorrow after clearing the caches.
PostPosted: Tue Nov 18, 2008 10:48 am    Post subject: RE: Web site banner ad Reply with quote
Adblock plus Smile
PostPosted: Tue Nov 18, 2008 11:48 am    Post subject: Re: Web site banner ad Reply with quote
wyliecoyoteuk wrote:
Adblock plus Smile
But I don't mind regular ads, they pay for the free access to web sites. The annoying, vibrating, "you have 3,648 viruses" are the ads I object too. Sites that allow this type of advertising don't get visited very often, if at all again.
PostPosted: Tue Nov 18, 2008 12:57 pm    Post subject: RE: Re: Web site banner ad Reply with quote
Adblock plus allows you to customise the blocking. You can just block the few you have trouble with, such as the offending one here.
Cheers,
Guy
The eternal noob
AndyBaxman
PostPosted: Wed Nov 19, 2008 9:15 am    Post subject: Re: Web site banner ad Reply with quote
Adblock plus Smile
While I agree with the principle of ad-funded sites, in practice they always end up showing the kind of annoying ads that set our teeth to grinding. Not their fault, exactly, but the fault of the ad agencies they syndicate to.
The effect, however, is the same. Eyeball-jarring ads that irritate the hell out of you on almost every ad-supported site you visit.
My response is to merely block the lot. See an ad, block its domain. End of story. Its the only way to have an acceptable web experience these days.
Advertisers whinge and whine about this attitude, to the extent that they even try to implement ad-blocker-blockers to keep people off sites if they have ad-blockers enabled. Doesn't work of course, the blocker technology is always ahead of them.
What these ad muppets need to grasp is that this situation is all of their own making. Unlike other ad mediums (TV, radio, magazines, cinema, etc) they cannot force ads upon us. We look at their ads on our terms, or not at all. If they hadn't started (and persisted) with the notion that they could shove any garish crap they like into our faces then the ad-blocker would never have been born.
PostPosted: Wed Nov 19, 2008 10:07 am    Post subject: Re: Web site banner ad Reply with quote
Hear hear, and the TV companies are starting to implement "anti advert skip" tactics into the way that adverts are shown.
Thing is, PVRs can skip most ads, but now they show the logo twice with a pause, so that it only skips 10 seconds.
They still can't disable the "skip forward" button (yet)
PostPosted: Thu Nov 20, 2008 11:06 pm    Post subject: RE: Re: Web site banner ad Reply with quote
It's strange, it's only on one PC that it's occurring (my staff one Rolling Eyes ) so i have just blocked images from m1.2mdn.net and the problem is solved.
Edit: Convinced support staff to make me a Power User and I upgraded to Firefox 3.0.4, re-enabled images from m1.2mdn.net and everything worked fine. Windows just makes computer use so frustrating Mad
PostPosted: Mon Dec 22, 2008 2:02 pm    Post subject: RE: Re: Web site banner ad Reply with quote
I've got the same issue running Ibex from LXFDVD114 in Virtualbox, my works laptop, colleague also displays the banner down screen instead of across. Plugins have been install but FF keeps advising that additional plugins are require. Going to try a reboot.
Edit
Just a close and re-open of FF to accept/refresh the install plugins cured the problem.
Post new topic   Reply to topic    Linux Format forums Forum Index -> This Website All times are GMT
