What does Linux know about your hardware?
Postby Dutch_Master » Thu Jul 24, 2008 2:02 am
On a regular basis (new) members ask help to 'troubleshoot' their system. In most cases it's pretty simple, but sometimes we'd need to know more about your system. I've created a little script you can use to do the 'dirty' work for you. Note that it currently only works on Debian based systems (next to Debian itself also any Ubuntu variant, Xandros and Knoppix) with the lshw package installed. Contributions to make the script distro-independent and a check of wether the required package(s) is/are installed are welcome :)
#! /bin/bash
# script to collect hardware and software data on your system
# you'll need to be root to get proper results
# currently only works in Debian based systems, with the lshw package installed
# what kernel are you running?
echo uname -a: `uname -a` > mysystem.txt
echo ========= >> mysystem.txt
# find out all you want from your hardware with lshw
lshw >> mysystem.txt
chmod 755 mysystem.txt
echo "done! read the file mysystem.txt in the current directory"
echo "use the cat and grep commands to select sections of interest if you're on the commandline"
exit 0
Save the above text in a text file named "mysystem.sh" or click the link ;)
Make it executable with
chmod+x mysystem.sh
and run it with
./mysystem.sh
The resulting text file "mysystem.txt" tells you all Linux knows about your hardware.
That simple? Yes, even 1sf (troll) could use it (although as Mandriva user he won't be able to run it, for now ;))
Anyway, this text file can be used to copy the relevant parts from in your reply (or even the original question!)
Frankly, I hope you won't need it, but if you do, let me know if it worked for you (it works on my system (pun intended :P))
RE: What does Linux know about your hardware?
Postby nelz » Thu Jul 24, 2008 8:25 am
Change
to
echo uname -a: $(uname -a) >|mysystem.txt
or it will fail if someone has the noclobber option set in their shell, or even
echo "uname -a:" >|mysystem.txt
uname -a >>mysystem.txt
which saves spawning another shell process.
Note that some distros install lshw into /usr/sbin, which may cause problems if you try to make the script distro-agnostic. Anyway, you should check that it is installed before trying to run it.
if which lshw &>/dev/null; then
else
   echo "You need to install lshw to use this script!
fi
Why do you make the output file executable?
Postby ollie » Thu Jul 24, 2008 11:02 am
After installing lshw (and dependencies) the script works fine on my Asus Eee PC running the default Xandros (updated) and my self built Intel Q6600 running Ubuntu 8.04.1. The output to text is well presented and easy to search through.
Great work DM, this should be included on the LXF DVD! :D :!: :idea:
Postby Dutch_Master » Thu Jul 24, 2008 12:02 pm
Nelz, thanks for the suggestions, I've incorporated them in the script. The reason I've put in the chmod line is because the file is created by root and may not be readable as normal user. Changed the permissions to 644, 'cause that does the trick as well :)
Ollie, glad you liked it. Not sure it's mature enough to be on the LXF dvd's though ;)
Postby ollie » Thu Jul 24, 2008 12:48 pm
I'm sure it is!
I'd add:
echo "System info at:" `date` >> mysystem.txt
at the start of the script just so you can check if the script was run before or after changes have been made.
Postby bobthebob1234 » Thu Jul 24, 2008 1:35 pm
erm, nelz
i think your missing an "
else
fi
should be
else
   echo "You need to install lshw to use this script!"
fi
I spent ages trying to get the script to work after i added your code!
Good idea though
bobthebob1234
Postby bobthebob1234 » Thu Jul 24, 2008 1:42 pm
'd add:
Code:
Prehaps having the file as
mysystem date +%D .txt
might be better?
(PS, i don't know the exact syntax... :roll: )
bobthebob1234
Postby pwbrum61 » Thu Jul 24, 2008 2:07 pm
For those of you who might dabble with Solaris, similar information to that from lshw can be obtained with
prtconf -v
Where's the Kaboom? There's supposed to be an Earth-shattering kaboom! :D
pwbrum61
Postby Dutch_Master » Thu Jul 24, 2008 11:00 pm
That's a very reasonable addition Ollie, you're in :) Had to change some bits though ;) Bob, thx for getting the typo, fixed it. Solaris, however tempting and interesting, is a step too far for now pwbrum61, first get some distro-independence on Linux ;) But I'll keep it warm for later use! :)
Postby ollie » Thu Jul 24, 2008 11:25 pm
Thanks :D
Postby Dutch_Master » Tue Jul 29, 2008 10:39 pm
Quick note to let you know that:
1) althought the script quoted above does work, it's version 0.001 and the link offers version 0.003 for 'download'. That is, the link always has the latest version available.
2) I'm downloading Fedora 9 ATM and will install it in a VirtualBox environment when done. Basic extention for rpm based distro's is therefor in progress. (but not yet available!) Don't hold your breath for it! ;)
Postby Dutch_Master » Thu Sep 18, 2008 12:07 am
Update 2:
Getting Fedora to work on a virtual machine turns out to be a PITA. Slow, slugish, not responsive at all. I instantly knew again why I chose Debian in the first place :P Tried OpenSuse too, same results :( Any rpm based distro you guys would recommend that runs acceptable on a virtual machine?
Postby ollie » Thu Sep 18, 2008 2:10 am
With current distros you will have problems if they are configured by default to use Compiz, which requires 3D acceleration, which means that openSUSE with KDE4 would definitely have issues. You may also have to give the virtual machine more RAM if it is running very slowly. That's the big advantage of having a 64-bit OS as the base OS, you can install and use plenty of RAM :D
Postby Dutch_Master » Thu Sep 18, 2008 2:21 am
Thanks for the warning Ollie, but as Gnomy I wouldn't choose KDE anyway ;)
The host has 2 GB RAM onboard, and 512 MB for a guest, and runs 64 bit Debian. Should suffice, shouldn't it? Frankly, any (modern) Linux distro that needs more then 512 MB RAM would be just as bad as M$ Vi$ta :evil:
Hmmm, would CentOS do, RH-based as it is? I'll see if I can get some .iso tomorrow ;)
Postby ollie » Thu Sep 18, 2008 6:25 am
Dutch_Master wrote:Thanks for the warning Ollie, but as Gnomy I wouldn't choose KDE anyway ;)
:lol: Gnomey still has Compiz.
I think CentOS would be closer to RHEL than Fedora.
I'm flat out with Software Freedom Day at the moment, but I'll see if I can do some testing on different distros after I have a week off.
8) No computers, no mobile phone reception - just fishing, sailing and pulling kids around behind my speedboat at Windamere Dam. :D
