Module names: What is the difference between "-" a
Postby alloydog » Thu Aug 11, 2005 9:07 am
A quick and easy one...
With modules, for example, as in /etc/modules-2.6.7, what is the difference between using the dash "-" or an underscore "_" ?
For example, what is the bifference between:
usb_storage; and,
usb-storage?
alloydog
RE: Module names: What is the difference between "-&quo
Postby nelz » Thu Aug 11, 2005 10:41 am
None, apparently
[root@hactar src]# modinfo usb_storage
filename:       /lib/modules/2.6.12-gentoo-r7/kernel/drivers/usb/storage/usb-storage.ko
license:        GPL
description:    USB Mass Storage driver for Linux
[root@hactar src]# modinfo usb-storage
license:        GPL
Postby alloydog » Thu Aug 11, 2005 11:18 am
thanks
alloydog
