Powerpoint alternatives that aren't huge
Postby dizwell » Tue Aug 02, 2005 11:26 pm
I don't do a lot of word-processing, so OpenOffice was overkill for me, and I accordingly am very happy with Abiword: small, standalone, sufficient to the purpose, bloody fast. I do even less viewing or producing Powerpoint-style slideshows, and I am accordingly very happy with...
Can anyone complete the above sentence with suggestions for a lightweight, standalone slideshow producer/viewer that is Powerpoint-compatible(ish). I get sent PPT slideshows I need to view sometimes, and I occasionally need to throw a slideshow together for my own use. But I really don't need a full-blown Office suite to do the deed.
I am using Fedora Core 4 x86_64. I've hunted on Google for 'powerpoint compatible slideshow linux' and similar, and some command-line stuff was suggested, but nothing like the 'Abiword of Presentation Software'.
All thoughts gratefully received!
Regards
HJR
dizwell
RE: Powerpoint alternatives that aren
Postby nelz » Tue Aug 02, 2005 11:59 pm
There's KPresenter, part of the KOffice suite. Depending on your distro, there may be a package for KPresenter alone.
Postby dizwell » Wed Aug 03, 2005 12:32 am
Thanks for taking the trouble to reply so quickly. I'm using Fedora 4, as I mentioned, and no separate download is available for that as far as I can tell. Looking at the KPresenter home page, I can't see separate downloads at all, in fact.
So I think I will have to pass on KPresenter for now.
Any other suggestions? (Polite ones, that is!) :wink:
dizwell
Postby ollie » Wed Aug 03, 2005 6:55 am
There is an X11 based presentation software called MagicPoint that may be suitable.
Hope this helps.
Postby nelz » Wed Aug 03, 2005 7:38 am
KDE only provide a single tarball for KOffice, but some distros build thins into a number of smaller packages for each component. It doesn't look like FC4 provides KOffice at all on the discs.
Postby dizwell » Thu Aug 04, 2005 1:59 am
Ollie: Thanks so much for that link. I always feel a certain sense of dread when I see a tarball rather than a yummable rpm, but I'll give it a whirl anyway!
Regards from Sydney
HJR
dizwell
