debian sarge 3.1 kde fonts and screen res.
Postby bigblack » Mon Aug 01, 2005 11:22 am
Hi all,
I have successfully installed sarge. However, the fonts in kde seem to be badly antialised. I have used the control panel to to no good effect. The fonts seem to be a lot smoother in gnome - although larger.
Also how do you change the screen resolution? I only seem to have two screen sizes.
All the best.
bigblack
RE: debian sarge 3.1 kde fonts and screen res.
Postby Flea » Mon Aug 01, 2005 5:31 pm
I noticed an improvement in KDE fonts after installing xfs (X Font Server).
$> apt-get install xfs
Dave
Flea
Postby bigblack » Tue Aug 02, 2005 4:00 pm
Sorted.
It was to do with xfree86. On installation I set a couple of wrong options. In the XF86Config-4 file there is a command that I noticed could be used to reconfigure XF86Config-4 which is 'dpkg-reconfigure xserver-xfree86'.
Ran it - changed some options - and now both the screen resolution and fonts are sorted.
Thanks for your kind help. :D
bigblack
Users browsing this forum: reklan and 1 guest
