Can anyone please recommend a distro?
Postby drt » Sat Jul 30, 2005 5:16 pm
Hi
I was wondering if anyone could please recommend me a Linux distro to use?
I have an AMD 64 3000 processor, running on an K8NS Pro motherboard, with 512mb RAM.
I don't use my computer as a server, so need something which is quick to load on startup. I currently run FC3 which takes about five minutes to boot up to the desktop, which is too long.
I'm not a complete Linux novice, but wouldn't say I was a power-user, either. I prefer the Gnome desktop, and was wondering if anyone had any suggestions as to the best distro I could install?
Many thanks in advance for your help!
drt
drt
RE: Can anyone please recommend a distro?
Postby coolclassic » Sat Jul 30, 2005 6:33 pm
Why not try Ubuntu. I use Kubuntu which favours KDE. Ubuntu is fast loading and easy to config down loads are a singe using synaptic or even apt from command line. Have a look at there forums if you don't believe me.
http://ubuntuforums.org/
The world is your playground why don't you play.
coolclassic
Postby bigbee » Sat Jul 30, 2005 9:45 pm
Maybe if you disable some of the services that startup at boottime you can speed up your boot-time.
Maybe you can try out debian (or one of its offspring) which let you install a minimalistic system (which can be expanded at your needs) instead of an all-in-one-preconfigured distro like RH, SuSE or Mandriva.
bigbee
Postby jer1ch0 » Sat Jul 30, 2005 10:35 pm
I second Ubuntu. It's got Gnome, that you want, Synaptic package management - excellent; Aand excellent help at the Ubuntu forums.
jer1ch0
Postby RD » Sat Jul 30, 2005 10:46 pm
I like mandrake though at the mo its giving me a head ach with the microphone but other than that its all good :D
RD
Postby drt » Sun Jul 31, 2005 5:24 pm
Thanks for all your help, I will try Ubuntu as suggested, and let you know how I get on.
drt
Postby marco.auer » Wed Aug 24, 2005 12:21 pm
I would also go for Ubuntu. It is easy to use and can be very powerful.
marco.auer
Return to Discussion
