PCLinuxOS 2008: Mini-Me released
Post new topic   Reply to topic    Linux Format forums Forum Index -> Announcements
davecs
PostPosted: Sun Jan 06, 2008 11:46 am    Post subject: PCLinuxOS 2008: Mini-Me released Reply with quote
The latest release of PCLinuxOS is a "Mini-Me" version, aimed at users who are prepared to install a pared-down version of Linux then add software from the repositories. A lot of work has been going on re hardware compatibility, and anyone trying this is asked to report any problems to the site: http://www.pclinuxos.com
This new version contains "ndiswrapper" and a number of shortcuts to enable you to get certain awkward wireless cards working.
This is in a Utilities folder which also contains shortcuts to add ATi/Nvidia drivers, ALSA setup, Make Live CD, Make Live USB stick, and Redo MBR (if Windows ate your master boot record and broke access to installed Linux). Also to setup your Clock.
This means that ONLY the keyboard selection pops up when booting the live CD.
Another major change is that you are not prompted for root and user passwords during installation of the Live CD, this is done on first bootup instead. There is no longer an option not to have a root password.
What I would recommend to users in the UK is that you run Synaptic once you have got your internet connection working, and change the default repository using "Settings > Repositories" to a European one, Belnet, nl.freebsd or Heanet especially, you will get faster download speeds that way. Default is ibiblio which can be slow from the UK.
Anyway you can find the iso here:
http://ftp.nl.freebsd.org/os/Linux/distr/texstar/pclinuxos/live-cd/english/preview/
davecs
PostPosted: Mon Jan 07, 2008 9:35 pm    Post subject: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
When I posted the above, the ftp site at Belnet was down, it's the fastest one for me:
ftp://ftp.belnet.be/pub/mirror/pclinuxonline.com/live-cd/english/preview/
And here is a link to Texstar's announcement at the PCLinuxOS site:
http://www.pclinuxos.com/index.php?option=com_smf&Itemid=58&topic=38535.msg286182
hecatae
PostPosted: Tue Jan 08, 2008 10:34 pm    Post subject: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
tried it with virtualbox, works lovely.
I'm thinking of wiping my current pclos2007 install and installing mini-me 2008, simply because there is so much on the full install I never use.
eeepclinuxos is based on mini-me 2008, and flies.
davecs
PostPosted: Tue Jan 08, 2008 11:36 pm    Post subject: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
I'm preparing to do the same, hecatae, but for a different reason. PCLOS 2007 is built on top of Logical Volume Management, and since I added a SATA optical drive this slows everything right down on bootup and closedown. You can't uninstall LVM without knocking out most of the system.
Minime does not seem to include LVM, I've installed it a spare partition, with LOADS of software from synaptic, and even though it's basically an updated version, for this and other reasons the whole thing seems more snappy and more stable (not scientific, just my perception).
PostPosted: Wed Jan 09, 2008 12:32 am    Post subject: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
Can't you tell LVM to ignore your optical drive? Chances are, the config (/etc/lvm/lvm.conf) already does this but uses the name for a PATA drive. Check the filter line in lvm.conf.
hecatae
PostPosted: Wed Jan 09, 2008 8:43 am    Post subject: Reply with quote
Thanks for that information davecs, looks like I'll be doing the re-install at the weekend then.
davecs
PostPosted: Wed Jan 09, 2008 8:13 pm    Post subject: Re: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
I did try that at first, but after an upgrade, LVM seemed to start ignoring the lvm.conf file. No idea why, I did research this on the net and the configuration I did to stop it trying to include my SATA Optical Drive should have worked but didn't.
In any case, the whole thing is far snappier now. I have one 500Gb hard drive so LVM is better of not there for me.
There's obviously been some fairy dust involved though, I've done an rpm -qa on my old system and loaded nearly every package I had, and then some, nearly all the system services are turned on, and it still seems quicker.
I actually think that this mini-me justifies the praise in LXF101 more than PCLOS2007 did!
PostPosted: Wed Jan 09, 2008 8:48 pm    Post subject: RE: Re: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
Perhaps it'll be on the #103 cover disc, they are promising a distro bonanza.
P.S. That theme on mini-me looks vaguely familiar Wink
hecatae
PostPosted: Wed Jan 09, 2008 11:26 pm    Post subject: RE: Re: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
Done a complete re-install today, love the new theme, and I no longer get the LVM issue when my pc shuts down.
M0PHP
PostPosted: Thu Jan 10, 2008 8:59 am    Post subject: RE: Re: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
Is it just me or does the PCLOS main website look awful in FF/IE/Opera on Windows? Am I being punished for using the devil's operating system? Screenshot.
davecs
PostPosted: Thu Jan 10, 2008 8:38 pm    Post subject: RE: Re: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
I'm forced to use IE on WinXP in work at it looks just fine there...
But you, M0PHP have a choice!!
hecatae
PostPosted: Thu Jan 10, 2008 10:59 pm    Post subject: RE: Re: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
1280x1024 resolution?
looks fine in 1024x768
M0PHP
PostPosted: Thu Jan 10, 2008 11:42 pm    Post subject: RE: Re: RE: PCLinuxOS 2008: Mini-Me released Reply with quote
Suppose I could SSH into one of our *nix email/file servers and run Elinks Wink
Weird... works at home on my Windows box (albeit at 1024x768) Shall have to investigate further to see if any of the css files are being blocked by our upstream proxy Confused
Post new topic   Reply to topic    Linux Format forums Forum Index -> Announcements All times are GMT
