[fixed] "only root can mount dvd" in SuSE 9.3 - he
Postby crussell » Fri Jun 10, 2005 4:06 pm
Hey all,
SuSE 9.3 keeps whining when I try to access my DVD drive as a user. It tells me only root can mount /dev/dvd on /media/dvd.
Before I start attacking fstab, here's the fstab entry for the entry:
/dev/dvd /media/dvd subfs noauto,fs=cdfss,ro,procuid,nosuid,nodev,exec,iocharset=utf8 0 0
Am I right in assuming all I need to do is add "users" to the string and I'll magically let me access my own data ??
TIA
Crussell
crussell
ANd the utterly obvious answer is ...
Postby crussell » Fri Jun 10, 2005 5:22 pm
Yes it does fix the issue.
I will now take my Linux ignorance elsewhere and bask in it for a while ...
crussell
RE: ANd the utterly obvious answer is ...
Postby Rhakios » Fri Jun 10, 2005 6:47 pm
Using subfs you shouldn't need to mount it, it should mount automatically. What might be happening is that the DVD is not mounted under /media/dvd, but under /media/volumename, where volumename is the label assigned to the dvd. For example, if I try the latest LXF dvd, I find it mounts under /media/LXFDVD68
This has something to do with udev, I believe (but could be wrong).
Postby nelz » Sat Jun 11, 2005 8:16 am
It's not udev, that only sets up device names. It seems to be subfs picking up the volume name.
Postby abhinav » Sun Jul 17, 2005 8:01 pm
Sorry for my ignorance, but I am having similar problem.
My cd's and dvd'd dont get automatically mounted. I have to mount them manually everytime I put them. and then unmount them.. which is pretty annoying. I am providing with my fstab file.
/dev/sda5 / reiserfs acl,user_xattr 1 1
/dev/sda7 /home reiserfs acl,user_xattr 1 2
/dev/sda1 /windows/C ntfs ro,users,gid=users,umask=0002,nls=utf8 0 0
/dev/sda6 swap swap pri=42 0 0
devpts /dev/pts devpts mode=0620,gid=5 0 0
proc /proc proc defaults 0 0
usbfs /proc/bus/usb usbfs noauto 0 0
sysfs /sys sysfs noauto 0 0
/dev/cdrecorder /media/cdrecorder subfs noauto,fs=cdfss,ro,procuid,nosuid,nodev,exec,iocharset=utf8 0 0
Can someone help me.. what is wrong here ??..
thanks in advance..
Abhi.
abhinav
Postby Rhakios » Sun Jul 17, 2005 9:09 pm
By the look of your fstab nothing is wrong. I assume you have taken on board the comments above about CDs/DVDs being mounted under a different name under /media.
Postby abhinav » Mon Jul 18, 2005 8:40 am
Yes Rhakios,
The I know about suse 9.3 mounting media under the label names. Thats actually even more annoying when I have to mount manually, because then when I unmount, these LABEL directories dont get deleted automatically and I have to delete them by hand!!! :(
abhinav
Postby Rhakios » Mon Jul 18, 2005 6:49 pm
Well, then there's definitley something wrong, but it isn't your fstab, that's fine.
