phil1ooo
Posted: Tue Sep 18, 2007 4:02 am Post subject: RE: No shoddy alpha release here... |
Hi to all..And thank you
I ended up ringing microsoft and they told me that vpc doesn't support linux at this time.
I ended up getting Vmware and it all worked first time round,So now i can run both windows and linux at the same time with a monitor each and also increased my ram to 8 gigs and give them 4 gigs each and it's there a dream to operate.
I do have one issue left on linux but ,,,When i try to setup skype i get a message that says ( dependantcy resalution fail ).Does anyone now what this is please.
Thanks again to all. |
pootman LXF regular
Joined: Tue Jan 09, 2007 12:25 pm Posts: 430 Location: Scotland, North of England
Posted: Tue Sep 18, 2007 9:32 am Post subject: RE: No shoddy alpha release here... |
I'm currently running new Gentoo on old hardware, installed using PCLinuxOS 2007 to get my wireless network up (to save re-compiling everything from the disc version). It takes about three days to go from a blank disc to a kde desktop (half an hour to set up and then three days to run 'emerge -DuN this && emerge -DuN that'). And then everything just works
(Except I blew up half the vg with /home on it yesterday. Nelz's fault. [sniff] ) _________________ This signature has been produced using traditional writing methods on behalf of The Campaign For Real Slogans.
To enjoy this signature at its best, adjust your monitor's resolution to 1024x768. |
nelz Moderator
Posted: Tue Sep 18, 2007 10:13 am Post subject: RE: No shoddy alpha release here... |
Why not install from compiled packages? It shouldn't take much more than an hour to get from a blank disk to a working desktop with Gentoo. Install everything from packages, then set your USE flags etc and emerge -e world in the background.
As for your vg, I don't know what I did, but at least I didn't break my own /home  _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
pootman LXF regular
Posted: Tue Sep 18, 2007 11:10 am Post subject: RE: No shoddy alpha release here... |
Ahem.
I'm too impatient to wait for the DVD to download to get KDE packages (I assume they're on there)... _________________ This signature has been produced using traditional writing methods on behalf of The Campaign For Real Slogans.
drinksoymilk
Joined: Thu Sep 13, 2007 3:27 am Posts: 3 Location: Mequon, WI U.S.A.
Posted: Wed Sep 19, 2007 2:40 am Post subject: Re: Microsoft VPC Linux support... |
| phil1ooo wrote: | | I ended up ringing microsoft and they told me that vpc doesn't support linux at this time. |
Microsoft's virtual products have been supporting Linux since Virtual Server 2004. Looks like the "support" person you spoke with should read my 9/13 post or the tons of information out there since 2004 (both in Windows and Linux forums and blogs). Even their search engine (Live Search) points to information to the contrary.
Glad to hear that things are working well for you with VMware. VMware probably has a means to copy/paste information between your Windows and Linux sessions, which is a feature not supported by VPC. |
phil1ooo
Posted: Thu Sep 20, 2007 12:30 am Post subject: RE: Re: Microsoft VPC Linux support... |
Hi ..my problem is istalling vmware tools as now as everything I try to get permission to allow me fails and as a windows user I'm not sure if the paths are the same or not but nothing works.
This is what it tells me in the box,,,,
Dependency Resolution Failed
Can't install Openoffice_org-pt-BR-2.1-0.26.i586[SLED10-SP1-updates].
since OpenOffice_org-pt-BR-2.1-0.21.i586[SUSE linux Enterprise Desktop 10SP1 10.1-0]is already marked as needing to be installed
Marking this resolution attempt as invalid.
I hope this helps out |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3359 Location: Birmingham, UK
Posted: Thu Sep 20, 2007 11:32 am Post subject: RE: Re: Microsoft VPC Linux support... |
That is telling you that you are trying to install two versions of the same package. _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
Rhakios Moderator
Posted: Thu Sep 20, 2007 6:22 pm Post subject: RE: Re: Microsoft VPC Linux support... |
Also, why are you using SLED updates when you told us in another thread that you were using Suse10.1? _________________ Bye, Rhakios |
phil1ooo
Posted: Sat Sep 22, 2007 10:50 am Post subject: RE: Re: Microsoft VPC Linux support... |
sled came in vmware tools,You know I haven't been able to do anything on this so called great linux system due to this fact,,I installed Suse in vmware it then told me I had to install vmware tools and it will not let me and it seems from most forums I've read this is a commen proplem yet no one knows how to solve it.I'm only trying out linux to see if some people I know tell me is true,,that it is better than windows and faster and other than the fact that it is open source which I have not yet had the chance to experience it is nothing but a headache because no two people using linux comes up with the same thing let along anything that works where at least windows is the same for everyone,,,My experience with windows is you can have fun not get headaches.And as for these forums other than replying me with obvious questions well it seems you don't know anymore than I do.
So please stop asking me stupid Questions. |
towy71 Moderator
Joined: Wed Apr 06, 2005 3:11 pm Posts: 4170 Location: wild West Wales
Posted: Sat Sep 22, 2007 11:27 am Post subject: RE: Re: Microsoft VPC Linux support... |
phil1ooo
If you want to experience Linux in all its glory you won't get it from running in a virtual space because of the underlying OS's limitations
Please don't be rude, most of us here are unpaid volunteers who genuinely want to help  _________________ still looking for that door into summer |
Posted: Sat Sep 22, 2007 1:01 pm Post subject: RE: Re: Microsoft VPC Linux support... |
I think that one of your problems is that you are assuming that there one Linux system, whereas there are many.
Installing a package tailored for one release (e.g.SLED) on another (e.g. Opensuse10.1) is a bit like installing a Windows 98 driver on an WindowsXP machine- it may work, it may not.
Some distros use .rpm packages, some use .deb , some use other formats.
The permission issue is (I think- it is difficult to be sure with so little info) caused by the repository not being added to Yast.
In Linux, it is best to use the Yast package manager (in K menu>system>administrator settings>software) to install packages, rather than just clicking on the package from the desktop If the package is not available, you can copy it to a folder, and make that folder a repository for Yast
Also make sure that you are using the correct packages - there are 32bit and 64bit versions, and the packages are different, as they are in 32 and 64 bit windows.
As for stupid questions, I think if you actually gave the people on here enough information, they might be able to help.
Rudeness and irrelevant ranting like "windows is the same for everyone" won't get you help or sympathy.
This forum is exactly that, a forum, not a helpdesk. The users on here use many different versions of Linux, for different purposes, and for different reasons.
(By the way, I have been employed on Windows networks since 1997, and I use Opensuse on several machines at work and at home) _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
Rhakios Moderator
Posted: Sat Sep 22, 2007 1:01 pm Post subject: Re: RE: Re: Microsoft VPC Linux support... |
| phil1ooo wrote: | sled came in vmware tools,
No it doesn't. SLED and VMWare tools have nothing to do with one another.
| Quote: |
VMware tools is available as an rpm to install, to configure it you need the kernel source package and gcc, both of which can be installed from YaST.
| Quote: |
Trying out Linux as a first-timer is never easy, especially if you confuse different versions.
| Quote: |
Which hasn't been and isn't my experience of Windows.
| Quote: |
It was a sensible question intended to help, if you can't accept it that's your problem, goodbye. _________________ Bye, Rhakios |
1slipperyfish Forum Jester
Posted: Sat Sep 22, 2007 6:33 pm Post subject: |
| Quote: | | My experience with windows is you can have fun not get headaches. |
well said
paul _________________ i am a follower of the culture
Posted: Sat Sep 22, 2007 8:29 pm Post subject: |
| 1slipperyfish (troll) wrote: | | Quote: | | My experience with windows is you can have fun not get headaches. |
You want a headache, I'm your man.
paul |
Well said  _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
Posted: Sat Sep 22, 2007 8:48 pm Post subject: |
| wyliecoyoteuk wrote: | | 1slipperyfish (troll) wrote: | | Quote: | | My experience with windows is you can have fun not get headaches. |
paul |
i love you  |
thanks
