IPod Mini and linux? [REOPENED]
Postby AJB2K3 » Thu Jul 07, 2005 7:27 pm
has anyone got the ipod to work with linux very easly?
AJB2K3
RE: IPod Mini and linux?
Postby skecs » Fri Jul 08, 2005 7:29 am
My daughters iPod Mini was detected straight away with Suse 9.2 and gtkPod under the Utilities => Sync menu and I believe that Suse 9.3 is even better with the iPod. Can't tell you much more - she caught me with it and took it off me, something about not trusting me with losing all of her music again :oops:.
Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered!
skecs
Postby AJB2K3 » Fri Jul 08, 2005 5:44 pm
cool it does but ive got a bug.
Ive got to turn the pc off to unmount it. (blooming mandriva.)
AJB2K3
Postby Rhakios » Sat Jul 09, 2005 1:09 am
Can't you umount as root? i.e. su -c "umount /mnt/ipod (or whatever it's called)"
Postby AJB2K3 » Sat Jul 09, 2005 8:47 am
no i keep getting unmount doesnt exist
WTF thats 3 command mandriva doesn't have modprobe being another.
AJB2K3
Re: RE: IPod Mini and linux?
Postby towy71 » Sat Jul 09, 2005 9:05 am
AJB2K3 wrote:no i keep getting unmount doesnt exist
well that command doesn't exist it should be umount
Dick
ps both these commands normally need root privileges
Postby Nigel » Sat Jul 09, 2005 11:07 am
towy71 wrote:ps both these commands normally need root privileges
you also need to have /sbin and/or /usr/sbin in your PATH to find them using the "which" command or to invoke them without fully pathing them. Most distros exclude these directories from normal user's PATHs by default.
RE: Re: RE: IPod Mini and linux?
Postby AJB2K3 » Sat Jul 09, 2005 11:29 am
doh thats dislexyia appearing againg. i found umount where it should be but im missing gtkpods shutdown scripts.
AJB2K3
Postby Rhakios » Sat Jul 09, 2005 2:31 pm
AJB2K3 wrote:WTF thats 3 command mandriva doesn't have modprobe being another.
Really?
[rhakios@atropos ~]$ whereis modprobe
modprobe: /sbin/modprobe.old /sbin/modprobe /etc/modprobe.preload /etc/modprobe.conf /etc/modprobe.devfs /usr/share/man/man8/modprobe.8.bz2
As mentioned above, it needs to be in your path for which to find, otherwise whereis can do so.
Postby AJB2K3 » Sat Jul 09, 2005 7:50 pm
thaks for the clues. it does exist but it means ive got to do /sbin/modprobe, how do i alter that to just modprobe?
AJB2K3
Postby A-Wing » Sat Jul 09, 2005 8:00 pm
do the following:
export PATH=$PATH:/sbin
you can then just run modprobe without doing /sbin first
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
Postby Rhakios » Sat Jul 09, 2005 8:39 pm
Of course, there is another way to do it without adding /sbin to your path. If you do:
su - -c modprobe
the extra dash gives you root's path. It isn't the same on all systems, on my SUSE box I do not have /sbin in my path, but I get routes default path when I su a command. I expect it might be in /etc/bash.bashrc somewhere. One thing that SUSE does do, if you issue unmount by mistake, it tells you there is no such command and to try umount :)
Postby AJB2K3 » Sat Jul 16, 2005 6:40 pm
this has been re opened because of more problems.
Im getting this message -
'/mnt/ipod/iPod_Control/iTunes/iTunesDB' does not exist. Import aborted.
Im still getting the Dnot disconnect mesage but the ipods not even mounted?
I need megger help but i cant find contact details to speak to the auther !! :cry: :cry: :cry: :cry:
AJB2K3
Postby jezjones » Tue Aug 30, 2005 10:47 pm
to AJB2K3....
I just got a shiny new mini ipod and apt'd gtkPod only to get the same message as you.
I looked up a manual howto for slackware (i use ubuntu) and it gave me a clue about the cause.
If your iPod is not automatically mounted then this might help..
http://www.linuxquestions.org/questions ... &artid=327
Otherwise if it is and then you get that message when trying to read the iPod in gtkPod then have a look in the folder where things get mounted... on your looks like /mnt, on mine it is /media
My system mounted the iPod as its name (CHEWN THIEF), not as iPod..
debblack@ubuntublack:~$ ls -l /media/
total 40
drwx------ 6 debblack debblack 4096 1970-01-01 01:00 CHEWN THIEF
drwxr-xr-x 2 root root 4096 2005-07-05 16:28 floppy0
drwxr-xr-x 2 root root 4096 2005-08-02 12:31 sda
drwxr-xr-x 2 root root 4096 2005-08-18 22:06 usbdisk
drwxr-xr-x 2 root root 4096 2005-07-27 21:40 usbdisk-1
SO now in gtkPod you can go to Edit->Edit preferences
then under the first tab i changed the ipod mount point to
/media/CHEWN THIEF
(and it accepted the white spaces)...
Then it worked .. although there is a warning about extended information, but the files appear and i write back to it aswell.
Hope this helps... (although it would have been nice to find some documentation that said this, instead of just listing all the benefits of the program).
Jez :-)
jezjones
Users browsing this forum: Majestic-12 [Bot] and 1 guest
