Tip of the Month LXF69
Postby skecs » Sat Jul 09, 2005 7:55 am
Just thought I post a quick correction to the code for Tip of the Month. The convert command is slightly wrong. It occurs after the title is set, and should read:
convert $TMP/$filename -font helvetica -fill yellow -pointsize 26 -box black -draw "text 10,40 '$title'" $TMP/$filename
This adds the text box 10 pixels from the left and 40 pixels from the top, if you want to move it just change these values. Don't forget the "|" between the other two code blocks. The full line is placed after the filename is set and ends up as:
title=`gawk -F \" '/\<b\>/ { print $1; exit; }' $PGE | sed -e :a -e 's/<[^>]*>//g;/</N;//ba'`
8)
Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered!
skecs
