Scripting on OSX
Scripting on OSX
Postby pins » Thu Jun 28, 2007 2:49 pm
Hello again, my chirpy, cheerful chums.
I have been asked to write a script that will 'preferably' run from an OSX server that will gather the information from 'system profiler' on a bunch of macs on a network.
I have tentatively told my boss that this is possible on the grounds that:
1. It's BSD based, so scripting should be quite powerful, and;
2. I thought someone else was going to have to implement it.
Does anyone have any experience of this, or any words of advice?
pins
RE: Scripting on OSX
Postby nelz » Thu Jun 28, 2007 3:42 pm
Google would have given you the answer to this, which is that you can use Bash, and examples of how to do it.
Postby A-Wing » Thu Jun 28, 2007 7:55 pm
I have never used it (I use bash, php or perl), but applescript is supposed to be good http://www.apple.com/macosx/features/applescript/. It should integrate with the OS in the way you want.
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
Postby ollie » Fri Jun 29, 2007 6:40 am
The easiest and cheapest way to do this with a lot more functionality is Apple Remote Desktop. It gets all of the information from System Profiler as well as allowing remote graphical access (I know you can also easily do remote desktop through VNC - I do it at home to manage my daughters Macs) and remote installation of software, updates, etc.
For a UK price of GBP349 (don't have that funny shape in Australia :lol: ) that allows unlimited client management it is very cheap.
Postby A-Wing » Fri Jun 29, 2007 8:17 am
Isn't ARD just a glorified VNC? Which you can get for free
A-Wing
Re: RE: Scripting on OSX
Postby ollie » Mon Jul 02, 2007 6:31 am
A-Wing wrote:Isn't ARD just a glorified VNC? Which you can get for free
As I said above, you can do it through VNC and manage each Mac individually, but ARD is VNC on steroids. You use it to manage multiple Macs at the same time, download scripts to multiple Macs, query multiple Macs for hardware and software installed, install software to multiple Macs and more. If you are manging a networked Mac environment it is brilliant in allowing remote troubleshooting and management.
