tedius
Joined: Fri Apr 08, 2005 4:20 pm Posts: 83 Location: Cambridge, England
Posted: Mon Jun 27, 2005 11:34 am Post subject: C++ macros |
I'm trying to write a macro that will call a function to copy some values.
The extract below is only a small part of my program but I hope it will give you the idea of what I'm trying to do.
| Code: | #define COPY_ATT(dest, source, num) \
copyAtt((dest)->att_ ## num, \
source,
num);
std::string[3] list;
class object
std::string att_1;
std::string att_2;
std::string att_3;
copyAtt(std::string att,
std::string[] list,
int index)
att = list[num-1];
int main()
object *pObj new object;
for (i = 1; i <= 3; i++)
COPY_ATT(obj, list, i);
What is happening is that the macro is evaluating to (on the first loop)
| Code: | copyAtt(pObj->att_i,
list,
1);
Where I was hopping for
| Code: | copyAtt(pObj->att_1,
list,
1);
Is it at all posible to do what I want, and if so can some one tell me where I'm going wong.
Thanks |
vorian
Posted: Wed Jun 29, 2005 9:30 pm Post subject: RE: C++ macros |
Macros are evaluated by the preprocessor not the core compiler. You should treat it like string substitution.
After the preprocessing stage your code looks like:
copyAtt((dest)->att_i, \
list,
i);
now the core compiler gets to work and seeks to find a att_i attribute (there is none ). |
jjmac LXF regular
Posted: Wed Jun 29, 2005 11:16 pm Post subject: RE: C++ macros |
Thats a really good problem
But, as suggested above ... the preprocessor can only reall do a compile-time substitution. And it will require a 'constant' to use in the substitution.
Where as, your looking for a run-time evaluation. I don't think the preprocessor can do that.
You would need to provide some trick to allow for a 'constant' to be passes, like the below.
| Code: |
for (int i = 1; i <= 3; i++){
switch (i){
case 1:
COPY_ATT(ob->att_1, i, i);
break;
case 2:
COPY_ATT(ob->att_2, i, i);
break;
That could get somewhat messy if you had a lot of strings to copy.
As a container ... why not use a 'vector' instead ?. Sounds like it would be perfect for what you see, to be doing there.
About all i know about macro substitions though, comes from here ...
http://gcc.gnu.org/onlinedocs/cpp/Macros.html
So i could well be missing something there
jm |
tedius
Posted: Thu Jun 30, 2005 2:18 pm Post subject: |
Thanks for the help guys.
I had sort of come to the conclusion that what I was trying was not going to work
The solution that I am using is just to remove it from the loop and do one line for each copy. It works, but with 34 attributes to copy I was hoping for something more cleaver.
jjmac.
The reason I didn't use a vector is that the struct that I'm coping to is already define, and I don't have control over it  |
jjmac LXF regular
Posted: Fri Jul 01, 2005 11:55 am Post subject: |
Arrha, i see
The "switch" will work though, it's just that the preproccesor will need a const at compile-time, for the substitution.
