via sound card drivers
Postby peters@powerspeed.co.zw » Wed Jun 29, 2005 12:50 pm
I'm running Knoppix live CD 3.7. I'm running it from the CD not the Hard drive. There is no sound and the sound card setup tells me that the card is not supported. The sound Card is on-board, the motherboard is a pcchips m955g with a via chipset. Is there anyway to get drivers for the card. I'm new to Linux.
I have searched google but i cannot find anything
Thanks For Any Help
RE: via sound card drivers
Postby towy71 » Wed Jun 29, 2005 1:27 pm
you should post this to the help forum!
Postby peters@powerspeed.co.zw » Wed Jun 29, 2005 1:54 pm
Thanks for the help
Postby nelz » Wed Jun 29, 2005 2:10 pm
You should also change your usename to something other than your email address, unless you particularly like spam.
Postby fingers99 » Wed Jun 29, 2005 6:09 pm
In Knoppix, snap open a terminal (icon like a TV, bottom left on taskbar) and type
lspci
which should enable you to identify the chipset. You can then use google or the knoppix or kanotix forums to see if a later version of Knoppix or Kanotix supports it.
fingers99
Postby AJB2K3 » Thu Jul 07, 2005 7:28 pm
or go to www.viaarena.com who make the chips !
AJB2K3
