Wesnoth Map Editor
Wesnoth Map Editor
Postby Guest » Mon May 02, 2005 2:28 pm
I recently installed Wesnoth 0.9.0 off the LXF DVD (67), and apparently, it has a map editor, but I can't find out how to start it! There is no executable anywhere in the source code, even after I ran configure and make. How do I start it?
I was going to ask at the Wesnoth website (www.wesnoth.org), but it was down. :?:
RE: Wesnoth Map Editor
Postby Guest » Mon Jun 27, 2005 7:24 pm
the command for the editor is 'wesnoth_editor'. when i downloaded wesnoth it didn't come with the editor. i had to download it seperatly. the package is wesnoth-editor.
hope this helps
