Restarting the Gentoo Installation (portage mirror problem)
Postby Peter123456 » Thu Jun 23, 2005 10:37 am
Hello All,
I have a problem to restart after a break with the Gentoo installation.
What happend up to now:
1. CD-ROM with a burned gentoo live cd because the computer has only a CD-ROM
2. Harddisk hdd prepared hdd1=boot, hdd2=swap, hdd3=root
3. copied the distfiles to directory "files" on hdd3
4. booting gentoo live cd
5. installed stage1 (source from hdd3)
6. installed portage (source from hdd3)
7. run command echo "local /mnt/gentoo/files" >/mnt/gentoo/etc/portage/mirrors #that should be a problem after restart the next day
8. edited /etc/make.conf
9. did NOT use "emerge --sync"
10. bootstrapped the system
11. run "emerge --newuse system"
12. run "chroot /mnt/gentoo /bin/bash"
13. configured and compiled the kernel
THEN I decided to stop and to continue the next day and used "exit", umounted everything and rebooted
The next day I restarted with
1. mounting as the day before,
2. run command echo "local /mnt/gentoo/files" >/mnt/gentoo/etc/portage/mirrors
3. "chroot /mnt/gentoo /bin/bash",
4. "env-update",
5. "source /etc/profile"
And wanted continue with
6. emerge grub
NOW MY PROBLEM: emerge tries now to download from the internet. It do not use the distfiles from the directory /files on hdd3 anymore as the day before. Again I never used "emerge --sync" as it is recommend in the magazine to prevent this problem.
How can I solve this problem? Thank you in advance
Peter
Peter123456
RE: Restarting the Gentoo Installation (portage mirror probl
Postby nelz » Thu Jun 23, 2005 11:52 am
You only need steps 3 to 5 when re-entering the chroot, step 2 only needs to be done once. However,m you haven't made the files available to the chroot environment, so the mirror is an empty directory, that's why it is trying to download. You need
1. mount --bind /path/to/files /mnt/gentoo/files
A chroot is a locked box, programs inside of it cannot access anything outside. That is why you need to map your files directory to somewhere inside the box.
Postby Guest » Fri Jun 24, 2005 8:42 am
Thank you very much for your answer. I solved the problem when editing the empty mirror file and added "local /files". After that, portage continued to take my files.
Best regards
Peter
Postby nelz » Fri Jun 24, 2005 8:50 am
How did you end up with an empty mirror file? According to the steps you described, it should have contained "local /mnt/gentoo/files".
Postby Guest » Mon Jun 27, 2005 7:30 am
Hello netz,
KDE is running now, so everything worked well. I suppose, that working in the chroot shell let the entry "local /files" work :).
Thanks again for your help
Regards
Peter
