Linux Computer hostname reading problem
Postby Bilb » Fri Jun 24, 2005 9:21 am
Basically the problem is that I have a user when he logs in finger, w or who shows his computer as an old computer from a while back.
ie
Login     Name                 Tty      Idle  Login Time   Office     Office Phone
jbl        Joe Bloggs         pts/7    1:28  Jun 24 08:47 (comp000)
Where dd login is actually at the computer named comp999
The comp000 was on a different IP totally and has been removed DNS, WINS and Active Directory. I have also wiped the utmp & wtmp on the server.
The users computer has no reference to comp000 either.
anyone got any ideas?
Bilb
RE: Linux Computer hostname reading problem
Postby Nigel » Fri Jun 24, 2005 12:46 pm
Is it perhaps still in /etc/hosts ?
Postby Bilb » Fri Jun 24, 2005 12:52 pm
nope, i did check that as well :(
The hosts file only contains localhost. It is also not in any samba files either :(
Bilb
