SUSE 9.2>9.3 upgrade USB broken, other issues..
Upgrade versus fresh install?
Upgrade
1
9%
Fresh install
7
64%
Another Distro
3
27%
Don`t bother, use what you've got for ever
0
No votes
Total votes : 11
RE: Re: RE: SUSE 9.2>9.3 upgrade USB broken, other issues
Postby Guest » Wed Jun 22, 2005 11:22 pm
Your kernel was telling you that it's compiled with USB support but you don't have a usb-?hci.o module loaded. If memory serves me usb-ohci.o is a compaq-based module and usb-uhci.o is an intel-based module. If you load the proper module at startup this should alieve this problem. The easiest would be to YaST->Install/Remove Software-> Search for proper module (minus the last .o) depending on your hardware and either install or update it.
