GMorgan LXF regular
Joined: Thu Jan 12, 2006 6:58 pm Posts: 684 Location: South Wales, UK
Posted: Sun Jan 28, 2007 1:03 pm Post subject: Shell Scripting - different users. |
I'm wondering if a single shell script can run processes as different users.
I want to run the following as root
/sbin/ipw3945d
sleep 2
/usr/sbin/NetworkManager
then run
nm-applet
as a normal user.
I'm using FC6. |
MartyBartfast LXF regular
Joined: Mon Aug 22, 2005 8:25 am Posts: 780 Location: Hants, UK
Posted: Sun Jan 28, 2007 3:28 pm Post subject: RE: Shell Scripting - different users. |
Yep, assuming you're running the script as the normal user you can run commands as root with
sudo /sbin/ipw3945d
and
sudo /usr/sbin/NetworkManager
You'll need to have appropriate entries in /etc/sudoers, something like
fred ALL= NOPASSWD: /sbin/ipw3945d , /usr/sbin/NetworkManager
If your script is running as root and you want to issue a command as a normal user you need to do
su - fred -c /usr/bin/nm-applet _________________ I have been touched by his noodly appendage. |
GMorgan LXF regular
Posted: Sun Jan 28, 2007 4:34 pm Post subject: RE: Shell Scripting - different users. |
| Will that second option keep the script running as root or will all subsequent commands be run as fred. Personally I'd prefer to avoid NOPASSWDing it. |
nordle LXF regular
Posted: Sun Jan 28, 2007 5:21 pm Post subject: RE: Shell Scripting - different users. |
If the script is run by root user there is no need to know the passwords of the other users.
Each command issued within
su username -c "echo hello world"
will be run as username. Once that command is finished the script carries on as the user who called it, root. _________________ I think, therefore I compile |
Posted: Sun Jan 28, 2007 5:45 pm Post subject: Re: RE: Shell Scripting - different users. |
| GMorgan wrote: | | Will that second option keep the script running as root or will all subsequent commands be run as fred. Personally I'd prefer to avoid NOPASSWDing it. |
If you omit the NOPASSWD: bit from the entry in /etc/sudoers then when your script does a 'sudo command' you'd need to enter the password of the account running the script (not the root password), however any subsequent sudo commands within X minutes will remember that you've authenticated yourself and won't ask for the password again (I can't remember what X is though!).
If you were to use the NOPASSWD: field as in my example that would allow user fred to only run the two commands listed without providing a password.
Another trick you can do if you want user fred to run something as bert without knowing bert's password is as fred do
sudo su - bert -c "some command"
and then have an appropriate entry in /etc/sudoers |
nelz Moderator
Posted: Sun Jan 28, 2007 10:12 pm Post subject: Re: RE: Shell Scripting - different users. |
| MartyBartfast wrote: | Another trick you can do if you want user fred to run something as bert without knowing bert's password is as fred do
You mean give fred permission to run su as root in /etc/sudoers? That's a very bad idea. A muchmore sensible option would be
| Code: | | sudo -u bert some command |
_________________ Unix is user-friendly. It's just very selective about who it's friends are. |
