Question about linux shellcode
Postby _cih_ » Fri Jan 05, 2007 1:36 am
Hello everybody,
I am trying to write a simple shellcode, but I am having some difficulties.
i.e
I have following codes ( with following hex represenation respectively ) :
jmp 0x8048243<main+91> (e9 3a 00 00 00)
mov $0x9ed, %ecx (b9 ed 09 00 00)
js 0x804824f<main+103> (78 00)
As you can see the problem I have are the 00-s in the shellcode.If i want to overflow a character buffer, such null bytes will be considered as end of string. Can anybody hint me on any workaround on one of the samples above ?
Thanks.
_cih_
Re: Question about linux shellcode
Postby Steogede » Tue Jan 16, 2007 10:13 am
_cih_ wrote:Hello everybody,
i.e
Thanks.
You have a shell that understands Assembly? Perhaps it would help if you mentioned which shell you are using, it certainly isn't BASH.
Steogede
RE: Re: Question about linux shellcode
Postby jjmac » Tue Jan 16, 2007 10:26 am
Why would you want to do that ?
http://counter.li.org
