root kit hunter
root kit hunter
Postby towy71 » Mon Jun 13, 2005 11:37 am
ok, installed rkhunter and ran it and it came up with the following:
* Filesystem checks
Checking /dev for suspicious files... [ OK ]
Scanning for hidden files... [ Warning! ]
/dev/.udevdb
/dev/.static /etc/.pwd.lock
Please inspect: /dev/.udevdb (directory) /dev/.static (directory)
Now what does this mean? And what should I do?
RE: root kit hunter
Postby youlikeicecream » Mon Jun 13, 2005 11:39 am
what does root kit hunter do ?
youlikeicecream
RE: root kit hunter
Postby firefox » Mon Jun 13, 2005 11:58 am
Hunts for root kits.
firefox
RE: root kit hunter
Postby Nigel » Mon Jun 13, 2005 12:02 pm
What it means is that you have some "hidden" subdirectories in your /dev directory (ie ones that will show up with ls -a but not with ls).
Now, that may or may not mean anything. You now have to try to find out what these directories were created by and why.
.udevdb looks OK - see http://www.linuxforums.org/forum/topic-43465.html
Can't find anything at the moment on .static
Similarly you have a file in /etc called .pwd.lock that it thinks is suspicious. Again I think it's a false alarm... see http://www.hgmp.mrc.ac.uk/cgi-bin/man.c ... ic=lckpwdf for more details.
RE: root kit hunter
Postby towy71 » Mon Jun 13, 2005 12:33 pm
these directories were created when I plugged in my pen drive and my multicard reader so all is cool :)
thanks Nigel it did help ;-)
Dick
RE: root kit hunter
Postby youlikeicecream » Mon Jun 13, 2005 3:33 pm
excuse me for being silly but what is a root kit ?
youlikeicecream
RE: root kit hunter
Postby towy71 » Mon Jun 13, 2005 3:35 pm
RE: root kit hunter
Postby youlikeicecream » Tue Jun 14, 2005 2:46 pm
So a rootkit allows you to use neat tricks to hide nasties on windows machines ?
Mike :)
youlikeicecream
RE: root kit hunter
Postby nelz » Tue Jun 14, 2005 3:33 pm
A root kit allows you to hide and run nasties on a Linux box.
RE: root kit hunter
Postby youlikeicecream » Tue Jun 14, 2005 11:39 pm
oh, on a linux box. Is it quite common? I thought linux was quite safe (as long as you know what it is that you run/open/etc) I tried to install an antivirus scanner today and i still haven't sussed it yet !?
youlikeicecream
