Jazzydude43
Posted: Sun Jun 12, 2005 2:56 am Post subject: problems with Madriva |
I haven't loaded Linux in about 8 years ... worked with Solaris a bit.
System is an AMD 2000+ XP Proccessor ..
384M Ram
Lite on CDrw
DVD drive
2 WD 40G drives on the Raid Controller (not in a raid)
Linux sees the 1st as hde has / (root) (hde1) and swap
2nd as hdf /home (hde5)
bootloader is set to boot /dev/hde1
/boot/vmlinuz
when it boots .. it get past all the normal bios boot screen and the raid screen ... shows the irq screen ..
when it tries to boot .. I get "Error loading operating system"
This was a windows system . and I didn't make it dual boot. Is the Mandriva having problesm with the drives being on the raid controller?
Since they are both the same type of drive should I make them a raid?
I put the HD drives on the raid controller to allow me to use the CDRW and the DVD and masters on the 2 main IDE channels.
Thanks
Dave |
