HD DVD player, and DVI.
Postby Xraynorm » Sun Sep 17, 2006 9:54 am
Hello.
Does anyone know if its possible to connect a HD DVD player (with HDMI) to a computer monitor with a DVI input.
You can buy HDMI to DVI adaptors(i think), but will it work?
C64, Amiga 500, Amiga 600, Amiga 1200 + 030, AMD K62-500, Sempron 2200, P3 Laptop, P4 Laptop, Acer One Netbook (Linux).
Xraynorm
RE: HD DVD player, and DVI.
Postby ollie » Sun Sep 17, 2006 11:03 am
There are plenty listed with retailers - you need to check if these are HDMI "compatible". That is - will the signal stay HD or will these cause the signal to be downgraded to "standard definition"?
The only way to do this would be contacting manufacturers directly or face-to-face (with a demonstration) in-store.
Postby Xraynorm » Tue Sep 19, 2006 5:39 pm
Thanks.
You need to check if these are HDMI "compatible"
Do you mean the monitor, DVD player, or cable?
Xraynorm
Re: RE: HD DVD player, and DVI.
Postby ollie » Wed Sep 20, 2006 10:09 am
Xraynorm wrote:Thanks.
My understanding is all of them - if one component isn't compatible the picture will be downgraded. More details at:
High-Definition Multimedia Interface
High-Bandwidth Digital Content Protection
Return to Off Topic
